Question about HP Presario C555nr Notebook
COMPUTER LOCKS UP
MY DAUGHTERS LAPTOP WHEN STARTED ALLOWS US TO SIGN ON THEN WHEN IT STARTS THE START UP PROGRAMS IT LOCKS UP AND I HAVE TO FORCE A SHUTDOWN, HOW DO I RESET TO THE DEFAULT SETTINGS SO THAT WE CAN GET IT UP AND RUNNING
  • 827 Answers
Tap F8 as the computer is turning on and you'll enter Advanced Settings. Start Windows in Safe Mode.
Then do a System Restore back to a point before the problem began.
Hope this helps
Chris (ziraffa)
Posted on Dec 29, 2008
My Dell LATITUDE 3440 START UP SCREEN IS LOCKED
With another computer create a bootable Flash drive using the following program.
http://rufus.akeo.ie/
Download Ophcrack
http://pcsupport.about.com/od/toolsofthetrade/gr/ophcrack.htm
Use Rufus to burn the ISO to your flash drive.
Roboot your computer, start tapping F12 just before the Leno Splash screen starts until the boot menu comes up.
Boot to USB and Ophcrack should start up on its own, allow the program to run and it will do the work for you.
Oct 11, 2014 | Computers & Internet
Starting problem it is asking me retstart some it dnt starts
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 10, 2013 | Computers & Internet
I have a Toshiba Satellite L505D. When I log into windows, the cursor and logo ring lock up after a few seconds. I have to force close and reboot in safe mode to use laptop. Could this be a bad hard...
As you are suggesting that you can work ok in safe mode it sounds like a start-up application may be the issue.
Try a diagnostic startup
Click >Start button and type msconfig
For XP >Start >Run type msconfig
From the window which appears select diagnostic start-up
Reboot
If this allows you to work ok you need to repeat the process this time rather than diagnostic startup in the msconfig console go to the startup tab and begin selecting each item in turn and restarting.
Once you get to the startup item which is locking the machine up search for the associated program and uninstall it.
That should resolve your issue
Oct 19, 2012 | Toshiba Satellite L505D Notebook
After installing a game on my acer extansa 5235, my laptop then switched itself off. Then when starting up my laptop, it comes up with the 'start windows normally' or 'launch startup repair (recommended)....
Hi There.
1. Power off the laptop
2. Power on and immediately after pushing the power button hit the F8 key continually until a DOS Window opens allowing you to boot to Safe Mode.
3. Using the Up and Down arrows, select Safe Mode with Networking
4. When you are at your desktop, do the following.
a. Start Button
b. All Programs
c. Accessories
d. System Restore
Once at System Restore, choose a time to restore to before you installed the game. Restore the computer to that time and it should return to normal.
It probably goes without saying, but I would NOT install that game again.
Regards,
Selk
Mar 27, 2011 | Computers & Internet
My daughter's computer is sitting at startup at microsoft corp screen --won't go to sign on. This happened when she was trying to load software at college. What can I tell her to do
something happens on your windows start-up.
you can check login with SafeMode :
1. restart your laptop
2. on first boot bios system -> Press F8 (to option safemode)
3. on safemode VGA not support -> it's normally
4. check you start-up with :
- Run
- type "msconfig"
- click start-up tab
- uncheck option where program alien.
Mar 02, 2011 | Dell Inspiron 1525 Notebook
I can't sign into my fb page. I am on my Daughter's computer & got on yesterday
are you sure you're typing your account information in correctly? Double-check that the Caps Lock key is not active. When you were last on your daughter's computer, did you sign out before closing the web browser? Have you run a virus/spyware scan recently with an updated antivirus/antispyware program?
There are 3 possible reasons why you cannot log into your facebook page- 1) Something is causing you to not type your account information into facebook correctly. 2) Someone else got onto your daughter's computer after you used it, and if you left yourself logged in, changed your password. 3) A malicious program or hacker has changed your facebook password information, so they may use it for their own purposes.
For all three, I would recommend these steps: first, try typing in your facebook account information again, being meticulously careful to input your information in correctly. double and triple-check the caps lock key. second, run a virus scan on your computer with updated antivirus software. third, after a failed attempt to imput your account information, beneath the text box where you would normally imput your password, there will be an option saying "Forgot your Password?" in small text. This will lead you to a page where you must answer the security questions you entered when you set up the account- but once answered correctly, will allow you to reset your password.
Have a good day, hope this helps!
Feb 27, 2011 | HP Pavilion dv6000z Notebook
My daughter has an Acer laptop running XP. The
Hi i'm Rain.
Follow the instructions below to resolve the issue.
  1. Click start.
  2. Click All Programs.
  3. Click Accessories.
  4. Click System Tools.
  5. Click System Restore.
Now Keep the default Settings { Restore my computer to an earlier state} and click next.
Now select a date that you know for sure is before the problem accured. Click next an allow the restore to correct the problem. The system will reboot after the restoration . Now a restoration complete notice will appear.
Click Next or Ok to continue to desktop. Your icons should all be back in place .
Nov 30, 2009 | Computers & Internet
Acer aspire 5520 won't load up upon reboot
when the computer first boots click alt f10 on your keyboard and it will take you to the acer restore program. you can then restore your computer to the default settings. you will be asked to hit enter before it will allow you into the screen
May 11, 2009 | Acer Aspire 5520-5908 Notebook
My daughter forgot her password
by starting the computer you just have to hit the F8 button and voilá there has to be the option to start with the confirmed mode so there is an administrator account with this account you can delet the password if the trik with F8 does not work just taka out the battery while the computer is on start it new and there will be the option you need
Nov 30, 2008 | Acer Aspire 5630 Notebook
HP Presario C555nr Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
