How to connect blue ray disc player to rca rear projection tv
Unfortunately, there are a couple potential problems. First of all, if you RCA rear projection tv is fairly old and is not a High Definition tv, you may not have an hdmi, dvi, or component connector cables inputs. Without these, you are left connecting your blu-ray only by the standard yellow (video), along with the audio (red and white) rca cables... either way, the High Definition portion of the blu-ray won't work with a non-High Definition tv. It may be time to buy an HD capable tv to use your blu-ray effectively...
Posted on Dec 29, 2008
How do I connect a blue ray player to this RCS model
Yes, web search "component to HDMI converter"
Dec 27, 2014 | RCA Televison & Video
How can I connect a samsung bdf5900 to my hitachi rear projection tv
Your TV is probably older and has Component, Composite and DVI connectors. HDMI is a newer connector that integrates sound. If your RPTV does not have HDMI but DOES have DVI, you can get an HDMI to DVI adapter on eBay or a computer store pretty cheap. You will need another way to get the sound from the Blu-Ray player, either external speakers connected to the player, or stereo RCA cables from the player to the TV (there will be a set of RCA audio plugs with the TV's DVI port).
Apr 30, 2014 | Samsung BD-F5900 Smart 3D Blu-ray Disc...
Crosley projection tv
Sounds like one is not recognizing the other, By you not being to get into the set up menu means it is not seeing your blue ray player. Are you sure they are compatible? If so then if there is another way to hook it up, like with RCA cables then try that. Also make sure that there is not more than one S-video option on it.
Mar 12, 2014 | Televison & Video
Can I use a blue ray with my tv?
Blu-ray players can be connected and used with any Television that has at least Composite video inputs. But the only way to access the high def is through either a HDMI connection or your Component Video connections. You DO need an HD compatible TV to see any benefits of Blu-ray. Check the back of your TV your RCA model should have 1 set of the Syncroscan HD component input jacks and be sure the Blu-ray player has the component out jacks since they are being phased out.
Just be aware of the following:
As of January 1 2011, all Blu-ray players that reach the market will be Image Constraint Token enabled as per the industry AACS Adopter agreement. What this means is that new Blu-ray players will only be able to output high definition content over HDMI. Film studios will be able to embed an Image Constraint Token on their Blu-ray discs restricting the Blu-ray player from outputting the image in HD over an analog output, such as component. Instead, images will be sent over component will be constrained to a maximum resolution of 540p.
The move is part of a strategy that is designed to move consumers to digital-only connectivity so that by 2013 all analog outputs on Blu-ray players will be phased out. Studios have not been permitted to embed this technology into Blu-ray discs prior to December 31 2010, so discs purchased prior to this date will not have their image constrained. However, users will now need to look for the Image Constraint Token on the packaging of Blu-ray discs released after January 1 2011, if they still rely on component out for their Blu-ray player.
Jan 30, 2011 | RCA Scenium HD65W20 65" Rear Projection...
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
Jan 02, 2011 | RCA F25645 25" TV
My sony wega 42" rear
it depends on the type of blue ray player you buy some only have hdmi output others have standard rca - yellow - red - white this is the one you need
Dec 29, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hooked it up to a blue ray player, no cable at all, just the blue ray, and i get no sound from the tv, just a picture
To connect the Blu-ray player to the TV, connect the Video OUT of the Blu-ray player to the VIDEO 1, VIDEO 3, VIDEO 4 port on the TV using the "RED/WHITE/YELLOW" Composite cable to get both audio and video. You may also connect the "Component OUT" port of the Blu-ray Player to the VIDEO 5 and VIDEO 6 port on the TV using the (Red/Blue/Green/Red/White) Component cable to get both audio and video from it. If you have any questions on connectivity, you may wish to reply with your query.
Thanks,
Pradeep
Nov 19, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Best way to connect DVD player to TV
U have a S-video connection in ur tv right?Use that for ur Blu-Ray player.Use the RCA cable Red,White for connections for the audio.
Mar 24, 2010 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
551 people viewed this question
Top Televison & Video Experts
