Question about Fuji FinePix S7000 Digital Camera
Fuji Finepix S7000 zoom error
I have a relatively new S7000 that refuses to work. I get the fatal zoom error whenever I turn it on! Is there a simple fix or is there a "cheap" place to send it for repairs.
  • 76 Answers
There is a kit available from fuji for this cam but to be quiet honest have tried this numerous times to no avail and ended up replacing lens block assy which is very expensive + takes time to replace.if not that old demand repair from shop you bought it from
Posted on May 13, 2007
    Genius:
  • 2,985 Answers
If it is 'relatively' new then the best place is the place you bought from- under UK legislation they are responsible to repair or replace. If you are not in the UK then look up the Fuji website for your country- technical help. there is possibility they will direct you to a suitable place.
Posted on May 12, 2007
I dropped my camera ,i can still look at my pictures but i can't take any new one's it say's zoom error
you have damaged the zoom cog loader on the camera there is sadley no easy fix to this it will need to be replaced by a service tech
Jan 18, 2011 | Fuji FinePix S7000 Digital Camera
Dropped my Fuji S7000. Am I doomed?
The lens is probably jammed internally. Get an estimate from your local quality camera shop. Sometimes the problem is easy to repair and sometime you'll need a new lens assembly (may cost more than the camera.)
Dec 16, 2008 | Fuji FinePix S7000 Digital Camera
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Epson cx 2900
If the error is fatal then there is NOTHING you can do at home to sort the problem out. If Epson are refusing to repair the unit because you have repeatedly used non genuine ink then you can try and take them to task on the legality of that decision (depending upon consumer law in your area) but the chances of you getting it sorted without costing a fortune are slim to none.
There is an error which shows up in the status monitor as MAINTENANCE error and this can fixed relatively easily. It's symptoms are similar. However, a fatal error is generally just that - Fatal - and there is nothing the home user can do as this generally requires parts fitting.
Your non genuine ink is almost certainly NOT to blame for the fatal error though. At worst the **** ink you use will clog nozzles and may even ruin the print head by clogging all the nozzles and causing only blank pages to be produced. BUT can you prove this to Epson in court?
My advice - bin the printer and replace it with one from a manufacturer who appears to give a damn about their products and customers as much as their fat pockets!!
May 26, 2008 | Epson Office Equipment & Supplies
Zoom error
Sounds like you have a problem with the optics of the camera.
May 07, 2008 | Fuji FinePix S7000 Digital Camera
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
ZOOM ERROR
What just started? The camera? Do you have fully charged batteries? Did you check the manual?
Dec 30, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital... Problem: Zoom Error
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 13, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
210 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
