Question about Eclipse Audio Players & Recorders
I just bought the eclipse cld and it won't turn on after charging for hours
I got the eclipse cld 4g mp3 player just the other day. it's been sitting hooked to my computer to charge for somewhere around 10 hrs, and it turns on and can be used while still hooked up. but as soon as i unhook it it turns off and won't turn back on. i've looked up all the manuals and done everything recommended, but can't get it to work. did i just get the biggest piece of junk or am i missing something?
  • 32,281 Answers
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Oct 01, 2012
SOURCE:
SOURCE: MP3 Player won't charge or turn on
ok.. put Hold on , reset then play :D itr will turn back on
Posted on Jul 01, 2009
  • 476 Answers
SOURCE: Player cannot get connected to computer-Philips GoGear SA3115
Install and run the Philips Device Manager software from the product CD.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and repair the firmware.
Posted on Apr 02, 2008
SOURCE: Mp3 Player Won't Charge
wiggle your usb cord - I had to wiggle mine a bit where it plugs into the usb port in the computer before it was recognized and listed as a device in 'my computer'. only then did it actually start charging; if your computer is not recognizing it is plugged in, it may not charge.. when i finally figured this out, the actual charging of my 4 gig audiophase mps only took 10 minutes- previously i was trying to charge it for hours without any luck.
Posted on Mar 09, 2008
SOURCE: i brought an Eclipse CLD MP3 and when i charge it,
I bought a Eclipse CLD MP3 Player, the music does not sound the same as downloaded. You can only hear the background vocals, not the lead singer. How do you fix this or is the MP3 ****?
Posted on Mar 08, 2010
SOURCE: I just bought a Jensen smpv-2gbub player. How do
How to charge the Jensen MP3 player - Model smpg-v2bub
Ignore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1. When computer is on and at windows screen, attach cable from computer to mp3player with mp3 turned player off. It will immediately show you a connect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3. Now turn the mp3 player on by switching the button on the right side of the device to the on position. It will suddenly show you it's charging - the battery on the front of the mp3 player will have a signal pulsing through it.
4. It will turn off after one minute. It's literally half charged now. Strange I know. Repeat from step 1 and it will fully charged.
If it doesn't fully charge after it turns itself off after 1 minute the 2nd time, then repeat steps from 1, one more time, but this time when it turns itself off after a minute, still leave it connected to the computer for 10 mins even though it looks like it's off. Then disconnect it physically from computer, turn it on with the on button on the right side, press the left side middle button twice and look at the battery on the screen - it should be fully charged now.
Posted on Apr 22, 2010
Testimonial: "Thank you very much, that would have been very helpful. Truth is, it was my fault, I was pushing the ON button instead of sliding it. DUH Peggy!!!"
Eclipse cld mp3 player
How old is the unit? Before the problem started, how were you using it? Would you charge it up, listen for an hour or two, and then charge it back up, or would you let the battery drain further?
Nov 16, 2013 | Audio Players & Recorders
Is there a way to delete the music on my Eclipse CLD 4GB MP3 player
When you connect your player to the computer and you copied the music files from your computer to your player. You can also select the music files on your player by right clicking on the music file and then click on Delete.
Apr 15, 2013 | Mach Speed Trio Eclipse 4gb Cld Mp3 Silver
My eclipse cld 4gb mp3player wont hold a charge
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
Eclipse mp3 player 4g wont charge
Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
May 04, 2012 | Mach Speed Eclipse 180 MP3 Player
Eclipse cld won't turn on
what i just did was made sure it recognized it on my computer and quickly unpluged it and put it in my xbox
Mar 12, 2012 | Eclipse CLD2 MP3 Player
I just bought the eclipse cld mp3 player for my niece a couple of days ago, i downloaded music to it and let it charge but i cannot get it to turn on!!!!!!!! It only turns on when it's plugged to the...
There are two things that come to mind, the new battery is not holding a charge, or there is a problem with MP3 players circuitry. Remove the battery for 60 seconds and re-seat it back in place hopefully this will reset the processor ic, if this fails take it back because there is nothing more that can be done since the item is under warranty.
Mar 01, 2011 | Eclipse CLD2 MP3 Player
Eclipse MP3 Player- Wont charge. I plug it in and it shows the hourglass then it will show a computer connecting/connected to a battery but it will not charge
People on other posts said to get a wall charger and that'll work. We looked for one, but couldn't find one. We ended up using a usb camera upload cord that had the same connector. It charged just fine after that. We have a 180 Eclipse mp3 player...I'm guessing the cord connectors are pretty universal.
Mar 14, 2010 | Eclipse CLD2 MP3 Player
I brought an Eclipse CLD MP3 and when i charge it, it says it's finish so i take it out and but it back in then chargeres another hour....is it charged all the way?
Nov 07, 2009 | Audio Players & Recorders
588 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Joseph Hoffmann
Jose Ma DM.
Jose Ma DM.
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
