Question about Refrigerators
Kenmore side by side model#363.9554780
I have a older kenmore side by side that is not cooling well and i read your posting from a year or so ago. I took the cover off inside the freezer and found that the coils were covered in ice and that the lower heater was blown and the upper one was not coming on either. I guess my question to you is do you know the part number of the heater kit for this model or were I could find it and do you think I should get a timer as well it seems to work when i turn the knob it cuts the frig off but I have not heard it cut off sense i have been having the problem. Thanks for your help you can email me back at want2blile01@aol.com
mikedurland
  • 481 Answers
SOURCE: Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Posted on Jul 18, 2008
bobicehouse
  • 1524 Answers
SOURCE: MZD2768GE Maytag S/S Refreg/Freezer freezer side coils iced up.
Yes to both questions.
Posted on May 04, 2009
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
SOURCE: I have a Kenmore refrigerator not cooling
You will need to replace the heating element, if it looks blacken, then it's not good. When good, it's a clear glass tubing with a coil that heats up. Call Sears for parts.
Posted on Jul 20, 2009
  • 13 Answers
SOURCE: I have a Jenn-Air side by side frig. The freezer
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Posted on Jun 03, 2010
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
I have a Kenmore refrigerator model number 25358685894. The defrost does not working. I have changed the heating element once about a year ago and thought it might be the same issue again. I notice when...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Kenmore Refrigerators
Kenmore Side by Side not cooling. New ADC board.
Good day,
It is possible the defrost control failed. If so, it would still be in warranty.
However, the most common part to fail, is the defrost thermostat which is located behind the rear panel, in the freezer compartment.
It is a small round disc about 1" in diameter, mounted to the top of the cooling coil.
It can be tested, with an ohm meter, but must be tested before it can warm to above 30 degrees. It should read zero ohms of resistance.
Rarely, as well, the main heater which is mounted to the bottom of the coil can fail. It's a calrod unit somewhat like the bake element of an electric range. Unplug it, and check the continuity with an ohm meter. It should test out in the 25 to 50 ohms range.
If both check O.K. then the timer has failed, and needs replaced.
Thank you for using FixYa
Jan 25, 2010 | Kenmore 53612 / 53614 Side by Side...
Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Older Kenmore side by side stops cooling, both sides
1st. >Check the defrost timer first.You should be able to turn it with a screwdriver.
2nd.>bypass the temperature control and if the Fridg. turns on ..replace the control.
Please Rate this !!! thanx ! I'll assist you if you need further help.
Dec 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Quit, but has power 106.56563400
is the compressor hot? if yes, unplug , let it cool, and replace relay assy.
Oct 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Not cooling
it might have got stuck in defrost look for the defrost timer if it is a older fridge you can manuley turn it out of defrost to buy you time to getting a new timer
Aug 08, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore not freezing nor cooling. humming noise
DONT SAY THAT COMPRESSORS BAD YET !!!! TECHCUMSE AND COPELAND ALL HAVE THE SAME COMPONENTS FOR STARTING THE COMPRESSOR. ALL COMPRESSORS HAVE EITHER A "PIN-TYPE PLUG-IN START RELAY, OR CAPACITOR START ASSIST RELAY" TO GET THE COMPESSOR TURNING.( FROST-FREE REFRIGERATORS ALMOST ALWAYS HAVE A START-CAPACITOR, RELAY, AND T-STAT COMBO ON ALL MAKES. THE IN LINE BI-METAL TYPE T-STAT THAT PREVENTS THE COMPRESSOR FRON OVER HEATING... THEY CAN GO WEAK. THIS IS THE "CLICKING SOUND YOU ARE HEARING !!! CALL A REPUTABLE DEALER THAT IS "FACTORY CERTIFIED" FOR YOUR MAKE AND MODEL AND GET A "FLAT-RATE" DIAGNOSTIC CHECK PERFORMED. NEVER LET A REPAIRMAN TAKE DEFECTIVE PARTS OUT OF YOUR HOUSE FOR ANY REASON. BY LAW THEY HAVE TO LET YOU KEEP THEM UNLESS THEY ARE REPLACING THEM COVERED UNDER WARRANTY FOR EXCHANGE. UNFORTUNATELY HUNDREDS OF CONSUMERS ARE "BILKED" BY THE " DOI-IT-ALL REPAIR-MAN. MOST MANUFACTURES ONLY HAVE 1 YEAR ON COMPRESSORS FOR REFRIGERATORS 5-10 YEARS ON A/C COMP. DONT BE AFFRAID TO WATCH AND ASK QUESTIONS TO REPAIRMEN YOU LET "INTO YOUR HOME".
Apr 27, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
