Question about Hitachi 57SWX20B 57" Rear Projection Television
Flashing Screen when earmed up ?
My Hitachi has started to flash/blink after warming up for about an hour. I read a similar problem reported in August ,06 by "Hitachi guy ". There were two responses quite different. I am hoping to narrow the cause of this condition. Thanx, Ed
  • 97 Answers
Set should take 90seconds to "warm up" maximum. Check high voltage circuit and flyback output voltage. Bad transformer or the regulator should be suspect.
Posted on Apr 29, 2007
Hitachi L42S504
I would suggest you contact Hitachi customer service to see if their database has this as a known issue in this set.
Mar 31, 2012 | Hitachi Televison & Video
How do you program?
Hello!
This could help
How to set the time:
1. Plug in the unit. Wait until the hour on the LCD starts blinking
2. Press the CLOCK button to set the correct hour
3. Press the SET button to switch to minutes
4. Press the CLOCK button to set minutes
5. Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
1. Press and hold SET until the hour begins to blink
2. Press PROGRAM until you see the tiny bell icon on the bottom of the screen
3. Press CLOCK until you get to the hour you want to start brewing
4. Press SET to switch to minutes
5. Press CLOCK to get to the minutes you want to start brewing
6. Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Please rate this answer. thanks
Nov 24, 2010 | Faberware FCP512S Cordless Electric Kettle
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi projection tv, no pictures, no sound.a red light blinkin
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Nov 13, 2008 | Hitachi 46GX01B 46" Rear Projection...
Farberware FCP512S coffee pot instructions
Plug the unit in
Hope this helps
Sep 09, 2008 | Mr. Coffee ISX23
Bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
May 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 57SWX20B 57" Rear Projection Television Logo
69 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
