Question about Spinmaster Air Hogs RC Reflex Micro Helicopter
Hey my heli will not take off or not turn on
Please tell me what to do and how please email me as fast as u can.
  • 30 Answers
I had the same problem, the first thing you want to do is make sure everything is off and you have to charge it for around 3 hours for the first time so make sure you let it charge until the red light stops blinking then make sure all the blades are correctly alligned then make sure the controller can turn on if thats all good then make sure you always turn the controller on first and then the heli and i figured out with the reflex that if you barely push up the throttle it wont even start to spin so push it up all the way or try the directional stick and see if it works
Posted on Dec 30, 2008
Hak 735 helicopter
Usually synching requires one device started before the other, meaning that you may want to power on the transmitter, then turn on the heli and try the heli first, then the transmitter second if that doesn't work. Otherwise there's usually a small button that is pressed to get the two devices talking to each other.
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Spins to left non stop and trim wont correct it
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Dec 26, 2009 | Air Hogs Havoc Heli Helicopters
It charged for 5 hours, and only flew 5 minutes
I'm afraid this is nothing unusual. Many helis run the same amount of time. Unless you have modified your battery setup you will be using nimh batteries and they are renowned for losing power and storage ability whilst not in use. You give almost no information so it's impossible to give any definite answers. How old is the battery? are you charging it with the correct charger? How fast did you run the heli? I ran two of the exact same helis only yesterday and I was lucky to get both of them off the ground three times before the batteries died and when Nimh die they just die very fast with little warning. Perhaps you could reply with more information as to the age of the battery etc as above. Just remember that batteries only have a limited life and with poor maintenance their lifecycle drops dramatically.
Dec 25, 2009 | Axial Syma 9086 Helicopter
Emails are delayed sometimes up to 20 minutes.
absolutely normal. e-mail delivered based on network traffic. More traffic = slow delivery. Less traffic = fast delivery.
Hey ... a message delivered anywhere in the world in 20 minutes. Tell your grand parents of this "problem".
Oct 05, 2009 | RIM BlackBerry Bold 9000 Smartphone
I CAN'T QUITE TURN GOOD YET.
Keep hitting the right trim button till the turning stops.
May 16, 2009 | Air Hogs Havoc Heli Helicopters
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Helico
Gyro is oriented, flip it over, or turn it 180, see if this solves the issue
Jan 23, 2009 | GWS Pg-03 Micro Piezo Gyro Pg03 Heli...
Problem with the back rotor.
make sure there is no debris such as hair thread or string caught in the back rotor. this will cause it to lock up. Remove it and try fiddling with the trimmer button to help it stop spinning the helicopter
Jan 07, 2009 | Air Hogs Havoc Heli Helicopters
Nephew lost directions for charging
make sure both heli and controller are off and batteries are new and then plug wire into heli and then turn controller on it doesnt matter abc, abc is just the frequency to controll heli just match with the letter under the heli
Jan 04, 2009 | Air Hogs Havoc Heli Helicopters
Spinmaster Air Hogs RC Reflex Micro Helicopter Logo
512 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
