Question about Toshiba Satellite L305D-S5895 Notebook
Frozen mouse with a touch pad laptop computer
Computer powers up, but mouse is frozen in the middle of the screen. Nothing happens when touching the mouse pad of clicking on buttons. Toshiba Satellite L305D-S5895, Mouse frozen, tried to restart computer and it does nothing different. Tried the F9 key and FN+F9 at the same time, and ctrl + F9, no change. Any ideas?
Does Norton antivirus protect against virus' etc on facebook, myspace, etc
  • northernrock Jan 01, 2009
    I have the same problem but i cant get it click into "my computer" as the mouse is frozen.
  • Anonymous Feb 25, 2009
    if the mouse is frozen, no one is going to be able to check under my compputer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Posted on Jul 08, 2009
    Novelist:
  • 176 Answers
Is this the first time you seen this happen or has it happened in the past ? If its the first time - check to see that your mouse is securely connected to the serial or usb port. Other things to check: (For Windows XP ) right click "My Computer" select "Manage", select "Device Manager", select "Mouse and other pointing devices", select "HID-compliant-mouse" right click to mouse properties, select "Power Management" tab and uncheck the options "Allow the computer to turn off this device to save power" . For Vista: same thing except instead of "Mouse and other pointing devices" click the section "Universal Serial Bus controllers" and then select USB Root hub to properties then select " Power Management".
If everything ok there and mouse connections are secured but still frozen after reboot try another mouse.
Posted on Dec 29, 2008
My touch pad mouse has frozen to middle of the screen and won't move and restarted my computer when can i do to fix it
Hello Dear,
You just need to check if your Touchpad driver is nit faulty. (My Computer > Right CLick > Properties > Device Manager). If there is any Yello or Red mark seems there is some problem.
You can uninstall and reinstall the driver.
With regards
FIXYA team
Oct 10, 2010 | Acer Aspire One Netbook 8.9" Notebook
Pointer stuck in middle of screen on my acer laptop,Help!!
Are you using a mouse or the touch pad? Make sure the touch pad is turned on.
Jan 06, 2010 | Acer Aspire 5100 Notebook
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
FROZEN CURSOR
Sounds like the touch pad is not working anymore. try using a USB mouse and see if that works. also, see if you can reinstall the touch pad software to fix that.
Aug 28, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
file:///C:/Documents%20and%20Settings/GX-620/Desktop/TouchPad_ALPS_v.7.0.1101.14_Vistax86.zip
reinstall your touchpad drivers, and make sure it is not switched off (if you were using an extra mouse)
May 13, 2009 | Acer Aspire 5315 Notebook
I have an HP laptop with a touch pad mouse that sometimes makes the cursor go all over the screen. When this happens, a small box appears on the tip of the cursor and nothing I do will stop it from making...
you need new touch pad mouse or reseat connectors on motherboard/touchpad, you will have to open computer to do this (not easy if you dont know how to do it)
May 09, 2009 | Toshiba Satellite M35X-S161 Notebook
Mouse frozen in screen center
i presume you still have the manual for that computer.... i believe the newer computers allow you to shut off the touch pad... look for the key combination for that
Mar 16, 2009 | Acer Computers & Internet
Check your drivers. Go into the device manager (start>control panel>system>hardware>device manager>human interface device) . If it shows a big yellow question mark, than it is a driver problem.
I would suggest that you either install or download the latest drivers for the mouse, and you can do this even without checking for a hardware conflict as stated above.
You can also access the control panel and trouble shoot your mouse through the mouse icon.
Even sometimes this may not work.....
I had an IBM brand optical mouse that continually plague me with problems until I gave it away with a computer that I built. The person who has it is still have occasionally issues with the mouse even with the proper drivers installed. I believe that it is a connection issue because sometimes the mouse will start working when you jiggle the male USB connection.
Oct 14, 2008 | HP Pavilion Media Center a1330n - AMD...
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
Jan 25, 2008 | Toshiba Satellite M35X-S161 Notebook
Toshiba Satellite L305D-S5895 Notebook Logo
1,225 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
