Question about Grohe 25 597 Talia Tub Filler w/Personal Hand-Held Shower
Leaking faucet I have what looks like a Talia tub filler w/o the hand held shower. It is not used much but recently the faucet has stated dripping. I have tried to hand tighten the handles but to no avail. I have the small decorative low roundish hot and cold water control mechanisms. I have taken the tops off, removed the screw and cover and further unscrewed the long tube-like piece but do not see any way to further tighten the valve to stop the water drip. Can you give me directions tro fix this problem.
  • Anonymous Mar 22, 2014
    shower redirect leaks water out faucet in shower
    Scholar:
  • 68 Answers
Hi johnparker,
The dripping is caused by the ceramic cartridge leaking. It is a non servicable part.
Couldn't find the model number listed but here is a Talia schematic.
http://www.grohecatalog.com/product/25596/
The replacement cartridges are list as 4 and 5 in for hot and one for cold. Also consider replacing part #7 it is a seat.
Good Luck and please rate this response, Phil
Posted on Dec 29, 2008
TRITON SHOWER WATER LEAKING DOWN WALL AT THE BACK
Sorry to say most parts are plastic and sometimes deform,the cost to repair could be more than a new unit.very easy to swap,bite the bullit
and replace
Jul 01, 2014 | Grohe 25 597 Talia Tub Filler w/Personal...
Can the hand-held shower hose be replace without accessing the plumbing underneath the tub? I can't figure out how to disconnect the existing hose from the diverter without cutting an opening under the...
No, you need to cut a hole. Usually an access panel is provided during the initial installation, either in the ceiling from downstairs or in the other side of the adjacent wall. But it's pretty easy to add one. After you cut a nice rectangular hole, you can cover it with a piece of painted plywood that has a trim piece attached to the plywood. The plywood is held in place with a couple of screws. When you remove the panel, the trim stays attached to the plywood. When you place the panel in the hole, the trim covers the gap between the drywall and the plywood.
Dec 01, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
Triton ivory 2 drips from shower hose when switched off any ideas or does it all need replacing thanks
heat from my shower keeps changing temperature, it will not hold the same temperature for very long...any tips ?
Mar 20, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
After installing moen model 82248bn(Monticello) tub faucet 3weeks ago it has had a consistent drip from the faucet(one drop every 7-8 seconds). This faucet is brand new and I cant imagine the internal...
Call Moen's customer service line. They are excellent when you have proof that you are the buyer of the product (Buy it for looks. Buy it for life.® ). They will walk you through the problem and give you a solution. send you a free part, tell you how to adjust, etc.
http://www.moen.com/consumer-support
Please rate me.
Nov 21, 2009 | Moen Villeta 3813W Glacier Single Function...
HOT WATER FROM TALIA FAUCET IN BATHTUB WAS RUNNING A GOOD STREAM AND SLOWED TO A DRIBBLE. WHAT NEEDS TO BE FIXED?
I called the Grohe customer support line and they told me the part I need and that it is under lifetime warranty.
Jun 19, 2009 | Grohe 25 597 Talia Tub Filler w/Personal...
Hand held shower in Jacuzzi tub not working
you may have something in the line,take it off and check both the line and the handheld.
Jun 08, 2009 | Price Pfister Roman Tub Hand-held Shower...
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Grohe 25 597 Talia Tub Filler w/Personal Hand-Held Shower Logo
497 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
