Question about Fuji FinePix 3800 Digital Camera
Batteries are going dead within 5 min
I have a Fuji Film 3800. I am using rechagable batteries and ever time I put a new set of batteries I can only use it for about 5 min or less before it goes dead again. Can you help me.
  • Kristin Christopher Apr 28, 2007
    I am using Energizer batteries. The 2 sets of batteries I have tried are brand new, never used. Do you suggest recharging the batteries and try again.
    I forgot to mention that the recharger I have is a 15min charger. Does that make a differans with the Energizer batteries.
    Genius:
  • 2,985 Answers
What type of rechargables are you using? Ni-Cad are reputed to have a 'memory' so that if recharged whilst not fully run down this is accumulated so that only the new bit of charge is 'active'. So-put the batteries in a torch and leave it on until the batteries are completely flat, then recharge. And/or get a couple of sets of Ni-Mah rechargeable and a suitable charger and start afresh.
Posted on Apr 28, 2007
How do u keep both tvs charged in the vehicle. One will go dead within 30 mins of playing
I suspect you are using an inverter to run your TVs, which are very power-hungry, thus no surprise that your car battery is going dead.
You could add another set of batteries in the trunk. I have done that with my RV, where I put two large golf-cart batteries into a food cooler. This gives me about 8 hours run-time with my TVs. You can connect these batteries to your car's charging system through a "battery isolator" which is basically a one-way valve for electricity. This way, you could run your auxiliary batteries right down, without affecting your car battery's ability to start your car.
Feb 11, 2017 | Cars & Trucks
Battery drained within a few pictures but over a weeks time. camera is shut off between uses
Rechargeable batteries will degrade the more you use it. Their maximum capacity will always decrease the older the battery is. So if the camera is over 2 years old, the battery probably can't hold much of a charge anymore. Also, the battery will discharge even when the device may not be on.
My recommendation would be get a new battery. It doesn't hurt to have another one lying around, and there are usually Fuji compatible batteries you can buy that will not cost quite as much as an original.
Thanks for reading and good luck.
Feb 04, 2011 | Fuji FinePix 3800 Digital Camera
My 3800 will not turn on. I hae put in brand new
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Fuji FinePix 3800 Digital Camera
Camera will not turn on
Have you tried a set of alkalines? They hold slightly more charge than rechargables. Also, your rechargables can go dead really, really fast. I use 'em but I always keep a set of alkalines handy, just 'cuz.
Jun 11, 2009 | Kodak EasyShare C703 Digital Camera
Battery fully charged but cannot use camera. Applied new batteries works in review mode only Fuji Fine Piix F420
My camera had a similar problem. It would work only in review mode and as soon as photo/film mode was selected it went dead. What I did was 'discharge' the battery totally and then fully recharged it. This can be done by going to Menu-Option-Setup-Discharge. After I had done this the camera stopped going dead but the battery still had a very poor lifespan. I bought a new battery and now the camera works as new. Hope this helps-Steve.
Aug 16, 2008 | Fuji Cameras
So picture
I have the same problem with my 3800. Turning into the sun will make it come on, put after you use it for a long time it will not come on at all until you let it set for awhile. This sounds like a design defect which Fuji should address!!!!
Feb 16, 2008 | Fuji FinePix 3800 Digital Camera
Battery life
Try buying very high quality recharable batteries. You might have low quality batteries and the camera eats the battery up quickly.
Jan 20, 2008 | Fuji FinePix S3000 Digital Camera
Immediate Battery Draining
I had the same problem with my A345, it got worse and worse until now, everytime I try to take a photo the camera turns off. My brother has the same camera, his also does this.
Dec 02, 2007 | Fuji FinePix A345 Digital Camera
Fuji FinePix 3800 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
