Question about Olympus Stylus 850SW Digital Camera
Olympus 850sw- write protect and picture error
Hi! I just came back from holidays and transferred all pictures and SOME video clips successfully into my computer. However, some video clips cannot be opened and the computer says that there is an error with those. During the holidays, when i on the camera to view some videos, the screen says PICTURE ERROR. I think this might be linked to why i can't open those video files.
Also, worse, now when i switch on my camera, the screen shows WRITE PROTECT and when i press the playback button, it says PICTURE ERROR with an icon on top showing a green key boxed up.
Can anyone troubleshoot the problem? Any suggestions will be highly appreciated. Thanks!
  • Chop89 Feb 18, 2009
    I plugged my camera into a mac when i usually use a pc to transfer pictures and now when i want to take a picture "Write Protect" comes up with a red exclamation mark inside a red box. The camera works fine without the memory card. I am using a MicroSD attachment if that makes any difference. I would be very grateful for any assistance.
  • Morgannnx14 Mar 23, 2009
    I tried formatting my card, but write protect still comes up! then the screen freezes.
    President:
  • 919 Answers
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Posted on Dec 29, 2008
  • Gillian Fewster Oct 26, 2011
    YOU ARE BRILLIANT - IT HAS WORKED! MANY THANKS, I THOUGHT I'D HAVE TO BUY A NEW CARD
  • solovej13
    solovej13 Oct 11, 2012
    I can't format the microSD: 4GB SanDisk memory card (This disk is inserted in OLYMPUS MASD-1 microSD ATTACHMENT), then I trying to... - the screen freezes in black. I think best solution for me is to buy other memory card and forget about all photos I lost, am I right?
Olympus Stylus 850SW viewfinder and photos pink and blurry
Pink photos are usually caused by White Balance being set wrong. You should see in the menu the WB icon. Change the icon to the symbol of the sun. Or.... just reset the camera back to the default settings by going to the camera reset in the menu. If this fails, then your picture sensor is needing to be replaced.
For the manual, go to the following site:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1365
Jul 05, 2014 | Olympus Stylus 850SW Digital Camera
My camera olympus 850 SW the lense turn on violet color thats why when im startng to video or take a picture its color is violet..
i don't have the solution but i experienced the same problem on my olympus 850sw
the images turns violet and the pixels are distorted
never see this kind of error ever a camera had
Oct 18, 2010 | Olympus Stylus 850SW Digital Camera
I have just returned from holiday had no problem with my fujifinepix 500 I transfered pictures to my laptop with no problem however now after replacing card back into camera I can no longer see my pictures...
If you used the camera's software to transfer the pics there is a possibility that all the pictures have been moved to the computer so there could be nothing on the card to view.
Have you tried to take a picture and see if it gets stored to the card? If it stores a picture to the card without error then probably the pictures have moved and not copied.
If the picture will not store to the card then there is a possibility that the card is faulty.
Regards.
Jul 10, 2010 | Fuji FinePix E500 Digital Camera
Problm with meu 850SW
You may try some recovery software to rescue the files on your sd card, here are some for your options.
Photo Video Recovery (for Windows)
Photo Video Recovery for Mac
Be careful: Before your files are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Jun 08, 2010 | Olympus ? 850 SW Digital Camera
How i can set date and time on picture of olympus...
The 850SW will not deface your pictures by scrawling numbers across them. However, the data is stored with every picture. Depending on the program and printer, you can print the date on the image, in the margins, or on the back. Please refer to the documentation for the program.
If you print directly from the camera, refer to the instructions in the "Printing" section of the camera manual (page 41 in my copy).
May 19, 2010 | Olympus Stylus 850SW Digital Camera
Pls help i have a problem with my olympus camera stylus 850sw, when I would turn it on it says write protect.what will I do...pls help
SD cards have a slide switch along one edge. The position nearest the contacts enables writing, the position farthest from the contacts protects the card from writing. If the slide is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try a different card.
Feb 06, 2010 | Olympus Stylus 850SW Digital Camera
Clean or format card error on Olympus XD card
There are most likely some "corrupted" images on your xD card. Very often a card reader "writes" data to the card while transferring or copying images into the computer. When you re-insert the card back into the camera, it doesn't recognize the new data (because it didn't create it), and gives the error, usually requiring a complete formatting be performed. There are also problems if you use a reader to rotate images, then re-install the card in the camera. The best way to accomplish what you were doing is to transfer the images into a folder on your computer, as the camera shot them (don't rotate them first). That way, you haven't altered any data on the card. For now, however, I suggest you format the card in the camera, so you can start with a "clean slate". Good luck.
May 02, 2009 | Olympus Stylus 850SW Digital Camera
XD card setup
hey, were you able to find a solution? Im having the same problem! thanks
Apr 04, 2009 | Olympus Stylus / mju 1040 Digital Camera
XD card setup
Try to clean contacts with 70% alcohol and q-tip.
Mar 29, 2009 | Olympus FE-210 Digital Camera
I can't figure out how to get video clips off my Olympus Stylus 830 and onto my computer. All of my pictures transfer but none of videos will.
the video clips have a different file ext than your pics-either use the software that came with the camera or try a memory card reader for your xd card to genericaly transfer to xp or vista
May 20, 2008 | Olympus Cameras
Olympus Stylus 850SW Digital Camera Logo
1,215 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
