Question about Linksys Wireless-G WRT54GS Router (e125894)
Problem with Lynksys WRT54-G
If I pull up my wireless networks, click on my Lynksys router, it says I'm connected but then it gives me the "cannot display webpage" for all websites. I've contacted my internet provider so I've ruled that out. I've also tried using someone else's unsecured network and I was able to use the internet with that so safe to say, it's definitley my router.
I've tried unplugging power, reseting the router...help please!
  • rcharris74 Dec 30, 2008
    hey,
    you lost me on the last part...the part about the IP address stuff.
    I reset the ISP modem, the Linksys router, rebooted, typed command, rebooted again, typed the command "all" which gave me the address information but I do not know what I'm looking at or for. Also, what does 19.168.1.1. mean?
    signed,
    confused...
    Problem Solver:
  • 11 Answers
This is a common problem with the Linksys wireless router. You will need to reset your ISP device, meaning the ADSL router, or Cable modem, reset the Linksys device, and reboot your computer in that order.
Next you "should" release the IP address of your computer once it reboots to Windows (assumed). To do this you click on RUN, type in CMD to get a DOS window. From that window type in "ipconfig /release" without the quotes. Then close the window. Reboot the comptuer again.
You will NEXT need to determine which device is acting as the DHCP server, the ISP device or the Linksys device. To do this you will need to open up the CMD window again but type in "ipconfig /all" without the quotes. If your ISP device is listed first, then it is likely the server for all available IP adress on your local network. This means that the Linksys has been assigned a new IP address. The Linksys must be the DHCP server in this case so that it may be accessed through 192.168.1.1 from your browser address.
To make the Linksys the DHCP server, you must connect your ISP device to the Ethernet uplink port on the back of the Linksys router. The Linksys router may then be connected to a Ethernet hub or act as your hub if you have no other.
I hope this shines some light on the problem.
Posted on Dec 29, 2008
I have a new toshiba laptop that I can't get to connect w/o wires to my lynksys...how do I get my laptop to be wireless??
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Nov 05, 2010 | Computers & Internet
My Lynksys WRT54G has suddenly switched my wireless connection to a generic unsecured connection and away from my own setup. How do I fix this?
Please Enter the ip address of the router in internet explorer and go to wireless security. In that window we can change the the security and can give security pin.
Aug 05, 2010 | Linksys Wireless-G WRT54G Router
Have lynksys wireless router but is unsecure -
You can enable WEP on your router to make your wireless network secure.
To access the screen of the router, type the ip address of the router in the address bar of Internet explorer or Firefox. By default the ip address of the router is 192.168.1.1. If this doesn't work, go to the command prompt (Start -> run -> type cmd). Type ipconfig. Copy the default gateway.
It will prompt you for a user name and password. By default leave the user name blank and then type admin in the password field.
Once you are in the Linksys screen, go to the Wireless tab -> Wireless security.
For the security mode, select WEP.
WEP encryption: 64bits 10 hex digits.
On the Passphrase field, type a wireless password of your choice, then click Generate.
It will give you a key. You will need to copy the wireless network key because you will need to enter this key on your PS3 and laptop. Take note that this is also case sensitive.
Once you click save settings, it will disconnect all your wireless computers.
You will need to manually enter the wireless network key on all your wireless devices. Without the network key, other computers will not be able to connect to your network.
I hope this helps.
Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated.
Feb 16, 2010 | Linksys Wireless-G Broadband Router
Connect my Lynksys WRT54G2 Router with my Belkin (F5D6231-4)
You can connect 2 routers to each other. But the IP address will be different for both the routers .
It will be better to keep different names for the wireless network.
If you keep the same name, then it doesn't mean that the signal strength will be good. Because both the routers will broadcast their own signals.
If you want to increase the signal strength then you can purchase a wireless range expander.
Click Here for more info about the networking
Nov 04, 2009 | D-Link Wireless Starter Combination Kit...
I changed the settings with help from lynksys and I can not sign on
are you trying to connect to the wireless network or you are trying to access the router set up ?
You can check the settings of the network.
Click Here for more solutions
Nov 03, 2009 | Linksys WRT160N Wireless Router
Connecting a laptop to internet via wireless lynksys router.
ok make sure your router is set up connect to your router and check under the wireless settings make sure you have made a custom name for your wireless network and have some network encryption enabled for it i prefer wpa personal over wep as wep can be cracked easily so after you make up a password be sure to remember it you'll need it later, so after all those settings are saved close that out and goto your laptop open up the wireless network connections and click scan after your network comes up double click it and you should be prompted for a password, enter the password you set up on the router and click connect, also windows will sometimes ask you to verify the password after you have entered the password you will hit connect after a short period of time it should connect to your router and internet is yours :) enjoy
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
Bridge or Repeter mode.
It is possible but you will need to flash the router with custom firmware.
Here is how:
http://www.dd-wrt.com/wiki/index.php/Installation
This is only possible if you have two wrt54-g routers that are of one of these types:
WRT54-G ver 1
WRT54-G ver 2
WRT54-GL
(there is a sticker on the bottom that can tell you what version it is)
This is the article that I followed and it workes great.
http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Apr 29, 2009 | Linksys Wireless-G WRT54G Router
My pc will not access my new wireless router
Hi there, and welcome to FixYa.
You have got yourself a very friendly neighbor, but give him/here coffee, not access to your network.
- what you have to do, is to find the reset button on the back of the router, press and hold for about 5 seconds with power on, and you have reset it to factory standard.
DO SET THE ADMIN password as the first thing you do, so that your neighbor can’t access your router anymore.
Give your network a network name so that you can find yours if there is more around you. Network name are called SSID, short for service set identifier
Now, go to Wireless -> Wireless connection, to set the Encryption security settings.
Set security mode to WEP,
Set the Transmit key to your choice, if you know that you wireless card has 4 keys as well, I would use key 4.
Set WEP encryption to: 128 bit 26 hex digits.
Go down to key 4, and find a combination of numbers and the letters a, b and c.
(ex. 414243444546474849404a4b4c) = 26 hex digits.
Save settings.
Now, before you leave, WRITE DOWN your SSID, your new password and key 4 with your settings, as you need to set your wireless card with the same settings.
Start -> settings -> network and right click your wireless connection and click properties.
At the top, choose Wireless network, find your network, (your SSID) choose properties and set these settings as you wrote down from the router.
Now, remove the cable and logo on wireless…..
/Teis
If this helped you, do vote.
Dec 11, 2008 | Computers & Internet
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G WRT54GS Router (e125894) Logo
55 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
