Question about Pioneer DEH-P6800MP CD Player
Harness problem the harness has no red wire what should i do??
Get anew plug. There about 10 bucks at pacparts.com.
Posted on Dec 31, 2008
Looking for wiring diagram for door locks on a 2005 f250
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES 12 VOLTS Yellow Ignition harness IGNITION RED / green Ignition harness IGNITION 2 Blue/green This wire is only required on the V-10 Gas engine. ACCESSORY RED / black Ignition harness ACCESSORY 2 Gray / YELLOW Ignition harness STARTER Dk.green Ignition harness KEY SENSE BLACK/ pink In airbag plug on right side of st. column TACH SIGNAL Use an injector DIESEL TACH SIGNAL GREEN / WHITE SEE NOTES Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires. LOCK WHITE/ red In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. UNLOCK BLACK/ white In harness above gas pedal On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel. DRIVER LOCK MOTOR Pink/black In harness above gas pedal DRIVER UNLOCK MOTOR RED / orange In harness above gas pedal PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER DOORPIN BLACK/ blue Above parking brake in DKP The vehicle's computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions. FACTORY ARM Yellow/black Above parking brake in DKP This is the driver's doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm. FACTORY DISARM Dk.GREEN/ purple In harness above gas pedal BRAKESWITCH Green At switch above brake pedal PARKLIGHTS Brown At light switch harness HAND BRAKE Lt.GREEN/ red At plug above handbrake lever HORN Dk.blue In airbag plug on right side of st. column
Dec 25, 2017 | Cars & Trucks
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Trouble shoot
I believe that's a Speed Sensor issue.
Diag:
1. Ensure mainshaft and countershaft speed sensors are installed properly. Disconnect mainshaft speed sensor harness connector. Using a DVOM, measure resistance between sensor terminals.
2. If resistance is not 400-600 ohms, replace mainshaft speed sensor. If resistance is 400-600 ohms, disconnect 25-pin PCM harness connector "B". Check for continuity between ground and 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
3. If continuity is present, repair short to ground in Red or White wire between PCM and mainshaft speed sensor. If continuity is not present, reconnect mainshaft speed sensor harness connector. Measure resistance between 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
4. If resistance is not 400-600 ohms, go to next step. If resistance is 400-600 ohms, go to DTC
P0720 (FLASH CODE 9) . Check for loose PCM harness connectors. Replace PCM with a
known-good unit if necessary.
5. Disconnect mainshaft speed sensor harness connector. Check Red wire for continuity between 25-pin PCM harness connector "B", terminal No. 15 and mainshaft speed sensor harness connector. If continuity is present, go to next step. If continuity is not present, repair open in Red wire between 25-pin PCM harness connector and mainshaft speed sensor
harness connector.
6. Check White wire for continuity between 25-pin PCM harness connector "B", terminal No. 14 and mainshaft speed sensor harness connector. If continuity is present, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary. If continuity is not present, repair open in White wire between 25-pin PCM harness connector and mainshaft speed sensor harness connector.
Mar 21, 2014 | 1998 Acura Integra
Car
Speed Sensor probably. Try:
harness connector.
Mar 21, 2014 | 1998 Acura Integra Type R
Wire diagram for the a/c cooling fan.. 1991 Jeep Commache
I am sorry but fixya doesn't have any wiring diagrams. They are copyrighted and not free to share.
Jul 22, 2012 | Jeep Comanche Cars & Trucks
Where is the transaxle fuse to the left hand side of the steering taped to the wiring harness? This is where Mitchell On Demand says it is...BUT I CANNOT FIND IT AND EVEN THE DEALERSHIP CANNOT HELP ME!
transmission diode is located in the red wire to transmission wire harness that feed power to the tcc solenoid inside the transmission side pan where valve body located the inside pan wire harness is the harness where diode located when you remove side pan cover the top red feed wire at top harness where positive diode tied in the red wire circuit.if you referring to diode instead fuse that only thing i can think of.
Nov 18, 2011 | 1996 Buick Century
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
Jul 02, 2011 | Hyundai Motor 2003 Elantra
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Wiring diagram for 1999 dodge durango
1999 DODGE DURANGO
4DR SUV
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED/BLUE (+) RADIO HARNESS
Accesory RED/WHITE (+) RADIO HARNESS
Ground N/A
Illumination BLACK/YELLOW (+) RADIO HARNESS
Dimmer ORANGE (+) RADIO HARNESS
Amp Turn On DARK GREEN/RED (+) RADIO HARNESS
LF Speaker (+) DARK GREEN
LF Speaker (-) BROWN/RED
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BROWN/LIGHT BLUE
LR Speaker (+) WHITE
LR Speaker (-) DARK BLUE/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BROWN/ORANGE
Amp Location PASS KICK PANEL
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
May 10, 2009 | Audio Players & Recorders
Color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Dec 28, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Pioneer DEH-P6800MP CD Player Logo
18 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
