Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Canon Ixus 40
Recently my camera fell to the floor,since then the lense will not close,the camera turns it self off every time i go to yhe picture or video function,please help
    Novelist:
  • 107 Answers
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Posted on Jun 16, 2007
How do iset date and time stamp on canon ixus 40
here you can find the manual for your product:
http://files.canon-europe.com/files/soft24168/Manual/IXUS30IXUS40_CUG_EN.pdf
if you go to page 76 of the manual, you'll find detailed instructions how to setup date stampo embedded in picture.
Let me know if this helped you, bye
May 04, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
I have a Canon Ixus 40 and the screen does not work now can it be fixed for a reasonable cost.
Depends on whether or not the camera can take a picture OK.
If no picture, you may wish to replace the camera.
If it takes a good picture, the LCD ranges from $40 - $120 and labour to change it. Contact Canon for a good service center.
Mar 20, 2010 | Canon PowerShot SD110 / IXUS IIs Digital...
Hello I have a canon IXUS 960 IS. Yesterday when I was using the camera it only closed half way when powering the camera off. Now the camera doesn't open fully and when pusing the "play" button the power...
If the outside of the lense get dirty, those small particles may prevent the lense from opening and closing 100% as nomal times. I had the same problem with my Sony. Here is what I did.
1- I cleaned the outside(sides not the lense itself) of the lense.
2- While turning the camera off, I press on the lense (up and down motion) NOT too hard for a few times untill it either retracted all the way inn or most of the way in. If most of the way in, press the lense a little harder untill it retracts 100%. If you turn it back on, it should work as normal unless some mechanical part of the lense is broken or dislocated. When it fully opens, clean up the outside of the lense and keep it always clean for normal operation.
Good Luck!!!!!!!!
Jun 11, 2009 | Canon IXUS 960 IS Digital Camera
Good morning, re: Canon Ixus 40 camera. Disassembeled the lense assembly. Lookibg for a step by step assembly instruction - how to insert and align correctly the lense concentric cylinders. Thanks Amos
From memory, you can unsolder the motor using solderwick. I would advise against unsoldering the photointerrupter however as it could be damaged easily. It wont completely detatch the circuit but will give you enough to dissassemble. Hope this helps.
Feb 28, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Mar 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Canon IXUS 40
Go to this link; http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=224&modelid=10599 and click on "Frequently asked questions" under "Tech support" in the search box type "reset", and the first item is "how do i reset my camera to default. Hopefully this solves your problem, if not please post again :)
Mar 30, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
UNIQUE PROBLEM: Camera stuck on Movie mode
It's a small world. I have an Ixus V2 on the bench with exactly the same problem. The sliding button on the camera mates with a switch soldered to a flat ribbon cable inside the camera. There are two small teeth which move the internal switch left ot right. What's happened is one of those plastic teeth has snapped off the external part and now it can't push the switch anywhere. If you pulled the camera apart you could push the switch into either record or review but that's it. It will stay in either of those positions. Which is a bummer. The only way to fix it is to buy the complete flat cable ribbon with switch attached and boy it's a long cable. Except for sending it away for repairs (expensive) buy a damaged one on Ebay and do a transplant. Just make sure it's suffering the same fault.
Jul 19, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
201 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
