Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Washing Machine 1200 Aquarius- Hot point- will not spin?
It is not the belt as it is fully in tact, the filter has been cleaned and the only other thing it may be (at least i hope) is the brushes - so someone tells me. I am going to buy a set tonight but how do i fit them? I also want to buy hard wearing ones any ideas? Thanks
    President:
  • 1,462 Answers
Hotpoint use two types of brush depending on the motor. if motor mounted at top of machine, brushesw are clip in and very easy to replace. look at new brush and you will see how it clips in. no need to remove motor. if motor at base of machine, brushes are screwed in with two screws per brush. rather fiddly to do in situ and you may be better of removing motor and doing job in an easy position
Posted on Apr 27, 2007
Problem with hotpoint aquarius wml520p 6kg 1200 spin washing machine doesent go into final spin
Have you checked the filter if fitted? Sometimes washing machines will not spin if they're not empty.
Jan 19, 2015 | Hotpoint Washing Machines
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
The washing machine wont empty the water out and spin but the belt is ok
hi
you need to clean the filter that is in the exit
of the washers water
Jan 13, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Washing machine not draining therefore not spinning
You will find the filter located inside the large black hose at the lower right rear of the m/c.
Remove lower panel and you will see the hose there.
Undo the large clip and remove hose and clean filter.
Plz rate this solution
Thanks
Dec 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF000 - water problems.
have u tryed to clean the fillter at the back of he machine
Jul 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
94 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
