Question about Panasonic PT-44LCX65 Television
Spots on the screen
TV is 17 months old. I've been seeing a few dark blue spots gradually appear over the last few months and now an orange spot has appeared in a different location. I use this tv as both computer and tv and it is on sometimes 20 hours a day. I have an extended warranty, but the repair shop will be taking it away for at least 2 weeks, during which time I will be tv & computer-less. Is there anything I can do or is this outside of my limited bulb changing talents. I have NOT changed the bulb yet.
  • Dennis Wenger Apr 30, 2007
    Thank You.
  • Dennis Wenger May 02, 2007
    While I'd like to think the solution was that easy, as clean as the rest of the house is, I don't understand how dust would enter the cavity to get onto the mirror. Having sufficiently ruined enough SLR viewscreens, I'd rather NOT be polishing any Hubble's myself :)
    The blue spots are in a near diagonal pattern and the Orange in a near corresponding spot on the opposite side of the picture as the largest blue one, so it seems pattern-like.
  • 4 Answers
In some cases i have had this problem being contamination such as dust in different areas on the mirror clean with windex and a soft cotton cloth.
Posted on May 02, 2007
    President:
  • 3,130 Answers
Your problem could be dust or dirt on the lens inside the reflection cavity or the problem could be the light engine. If the problem is the light engine, thank god you have an extended warranty as the light engine alone cost somewhere around 1000 buck. Good Luck.
Posted on Apr 27, 2007
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
Dark spots on LCD screen
I hate to say it but what this is is contamination under the actual LCD glass. This propblem starts during the manufacturing process and can rear its ugly head over time or after running at high temperatures for long periods of time. It can also appear as dark 'tiger' stripes. There is nothing that can be done to repair this. If you have an extended warranty, the mfg should exchange the panel for you. If your warranty is up, take photos and contact Toshiba online and try to get them to cover this regardless. This is a mfg defect.
Jan 05, 2010 | Televison & Video
Dark spot on right side of LCD screen in the shape of Illinois has appeared gradually over the past few weeks. Very noticable between commercial and when news channels show graphics/slides. Pixels are not...
In most of the case, the problem is a defective display LCD panel, this problem in some terminology is called PIXEL RETAINING, it means the pixels are locked up, there is no good permanent solutions for it, you have to change the LCD panel.
Jun 02, 2017 | Vizio L32 32 in. LCD HDTV
Very slow to turn on and has small light spots all over screen
The first thing to look for are swollen capacitors on the power board.replace them if so.
Sep 11, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Sony Plasma 42 fwd-42pv1 interference / spots
thats a defective light engine..............new tv buddy..............its a known sony problem..........dont listen to thier b.s.
Dec 18, 2007 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-44LCX65 Television Logo
191 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
