Question about Apple iPod nano MP3 Player
My iPod is being rediculous.
When I went to connect my iPod into the computer, it said that there was an error and that I needed to reformat it, but when I tried, it said that I couldn't due to the fact that there was an error...? When I unplugged it my ipod's screen went white with a checkmark in the middle. it says "OK to disconnect", and it wont turn off. The screen is lit up too....
    Brigadier General:
  • 8,619 Answers
Hi! I think there is a virus in your iPod. Check your ipod with an antivirus when it is in diskmode. Then you need to open itunes and restore your ipod and will restore it to factory settings.
And if it doesn't work then Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect.
After doing this open latest version of itunes and then restore your ipod to factory settings by selecting it from itunes.
Posted on Dec 29, 2008
Itunes freezing when ipod is connected
Need to reformat your ipod - don't disconnect the ipod until you hit eject - ever you should be able to use it again try a different cord and reformat then have fun cause you get to reload all the music unless you were able to save your iTunes library
Jan 16, 2013 | Apple iPod classic MP3 Player
How to reformat my ipod using itunes?
How to Reformat iPod In order to reformat iPod to work on both Mac and PC, connect your iPod to a Windows computer. Then follow the steps in the how to restore your iPod article. This will reset your iPod and format it for Windows.
Now, resync your iPod with the computer that contains your iTunes library. ITunes will ask you if you want to erase and sync the iPod. If you say yes, this will redownload your iTunes library to the iPod.
At this point, you may also need a way to easily move your iTunes library to the second computer. A quick way to do this is with software that copies the contents of your iPod to a computer. Learn more about iPod copy and backup software here.
Checking iPod Format Each time you sync your iPod, you can check what format it is. In the iPod management screen in iTunes, there’s some data at the top of the window next to the image of your iPod. One of those items is “Format,” which tells you how your iPod is formatted.
Suggested Reading
Mar 27, 2010 | Apple iPod nano
I reset the my ipod just like the apple web site said. Then it showed a power cord going 2 an outlet from the wall. So i plugged it in the wall. It still showed it. Then I pressed the menu and center...
You must have a 3rd or 4th gen Ipod. It should not do this with a reset. If you reformat it through Itune , then it will. The plug into a power outlet means it is trying to reformat. If it will not, your hard drive is corupted or logic board. If it is the hard drive and you can get it to show on your computer, you can go to your disc utilities and erase the hard drive by writing zeros. then connect to Itunes and reformate. Plug into a power wall charger and it should complete. You need a good charge in your battery. If your battery is not charging or needs to charge , that will stop it from completing a reformat. I hope this helps.
Feb 07, 2010 | Apple 20gb Ipod Mp3 Player With Click...
IPod nano 4G that iTunes no likey
reformat your ipod, if you installed itunes via disc or from file, you should have the option in itunes to restore your ipod to factory settings. If you have songs on your ipod that arnt on your computer, you will need to copy them off the ipod before you restore your ipod.
To copy music off an ipod that is YOURS (in XP) go to my computer>click on your ipod> then go to tools>folder options>View TAB>and click on the option "show hidden files and folders". Then there should be a folder somwhere in your ipod (depending on what ipod you have) that says music. Copy that folder to the desktop and filter through all of the folders inside it for your music.
Mar 30, 2009 | Apple iPod nano
Hey check out this link it worked me..
Dec 15, 2008 | Apple iPod classic MP3 Player
To fix unknown error 1418
install itunes
May 29, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Help to solve my iPod Problem
first connect it to the computer, check to see if it's recognized by the computer. Make sure everything else is working fine, like transferring songs, video, sound, everything. If the ipod's still doing the same thing I would suggest reformatting the ipod.
Mar 04, 2008 | Apple iPod nano
IPod connection bugs
plug ipod into each usb slot until your computer recognizes this device somtimes this is the solution
Nov 16, 2007 | Apple iPod MA446LL/A MP3 Player
You will have to connect it to your computer and reformat it. It will wipe everything off.
Keep me posted.
Oct 29, 2007 | Apple iPod nano
Apple iPod nano MP3 Player Logo
59 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
