Question about Kenmore 92172 / 92174 / 92179 Electric Kitchen Range
Safety fuse? Will this fuse need to be replaced or just re-set?
  • Eric Smith Apr 28, 2007
    I took the back off the oven and can't find that part. The only part that looks close is a WP 3196958. Not sure if this is the thermostat safety switch or not. Do I have to take any other panels off the back to get to the thermostat?
    Novelist:
  • 116 Answers
The fuse is typically a one time item. It should be replaced. The oven will act as if it is pre-heating but will not actually heat. There is usually a couple of different ones in use , one common part number is a whirlpool part 4451442. This may not be the actual one for your range but it will be similar.
Posted on Apr 27, 2007
What tools are needed to replace starter on 2004 jeep liberty
A standard set of sockets/ratchets and extensions. Unhook battery cables or pull relay/fuses to the starter so you do not fry something.
Jul 30, 2015 | Jeep Cars & Trucks
Tip
Use of Fuses in Equipment for Safety
Never bypass a fuse. Replace it with the same rating of fuse. Do not use a wire to replace the fuse. Fuses are used for the protection of the equipment & safety of the user. Doing anything against these rules means your equipment will have more damage & may catch fire.<br /><br />- sonsunny
on Jul 09, 2011 | Televison & Video
Replaced air compressor in1999 mercury mystique replaced fuses worked for few minutes then stopped
If you mean A/C compressor, there are safety switches for high and low pressure. You need to evacuate the A/C system with a Vacuum pump and then fill it with Freon. If you already did this, chances are that when the Freon stabilized, it was either too high or too low of a pressure and the safety switches worked.
Apr 23, 2014 | 1999 Mercury Mystique
Microwave blown fuse
You will need a set of safety torx screw drivers to remove the cover of the microwave. On the circuit board you should see the fuse. In some cases the fuse is soldered in and cannot be changed with out the use of a solder extractor and solder iron to reinstall.
Apr 15, 2014 | Open Range 2013 345RLS
Vehicle suddenly will not move out of park, engine starts
sounds like a parking relay. have your relays checked by a mechanic.
some cars had a safety feature installed in the seat, that would not let the car out of park if someone was not setting in the seat. bounce a bit, in the seat, and try it again.
Jan 11, 2013 | 2005 Dodge Durango
The difference between thermal fuse and thermostat
Thermal fuse is a heat-sensitive safety feature that shuts down system when overheating is detected.
In electrical wiring, the thermal fuse reacts to high temperature caused by too many amps on the electric circuit. When temperature exceeds the fuse amp rating, then the fuse trips and cuts power to electric circuit.
Example of thermal fuse is a household circuit breaker.
Gas water heaters have a different type of thermal fuse located in the combustion chamber or on the combustion chamber door, and also inside a copper probe inside water tank. Water heater thermal fuses will trip when water temperature exceeds fuse rating, or when heat inside the combustion chamber exceeds temperature rating of fuse. This action will cut off gas supply to water heater.
So a thermal fuse is a safety feature.
Thermostat is not a safety feature.
Thermostat is a measuring tool.
Thermostats measure temperature.
Example of thermostat is outdoor thermometer, or cooking thermometer, or Heat-AC control located on wall inside house.
Thermostats can give a simple temperature reading, or they can cause a separate control to turn on-off depending on application.
For example thermostat on Heat-AC will read room temperature, and when temperature exceeds setting, this triggers a switch that turns Heat-AC on-off.
Many appliances have both thermal safety fuse and thermostat.
Take for example a gas water heater. A copper tube extends into the water tank. Inside the copper tube are 2 things: A thermostat probe to measure water temperature, and a thermal fuse called an ECO for energy cut off. The ECO is a thermal fuse, and is a safety feature.
http://waterheatertimer.org/images/Gas-valve-ECO2-358.jpg
The thermostat reads temperature of water, and turns water heater on-off to keep water hot. A person can adjust water temperature by adjusting the thermostat dial on front of water heater.
However if the thermostat fails, or some other problem occurs, and water inside the tank gets hotter than 180 degrees, then the ECO or thermal fuse will trip. When the thermal fuse trips, this turns off gas to the water heater so water cannot get any hotter. The safety device prevents water heater explosion. The water heater must be repaired since this particular thermal fuse cannot be re-used afterwards, and must be replaced.
Oct 11, 2012 | Dryers
Difference between thermostat and thermal fuse
Hello Mary
Neutral safety switch
most gm nuet safety is yellow and purple .....out of ignition switch is a big yellow wire that is crank out and input to nuet saf switch......out of nuet switch is color purple that goes strieght to start selenoid.....purple wire also goes to the crank fuse 5amp.. in the fuse box under dash... this fuse goes to the pcm main computer.. same for auto and clutch
Sep 04, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
My Bose wave radio suddenly is dead as a doornail. It showed no signs of malfunction, just won't work now.
Perhaps it is just a fuse blown. There is one small fuse inside the unit. If the fuse is OK, then the next step might the transformer. If the transformer is OK, then it might be the Bridge rectifier IC GBU series
Jun 07, 2009 | Bose Wave Radio
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Kenmore 92172 / 92174 / 92179 Electric Kitchen Range Logo
154 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
