Question about Casio QV-3500EX Digital Camera
Backlight on LCD
The backlight on my LCD seems to be broken. Does any one know if it can be fixed?
If u break that its done for
Posted on Oct 22, 2007
    Genius:
  • 2,985 Answers
No fixee - new camera if you really, really new the rear screen
Posted on Apr 28, 2007
How do I repair backlight?
Repair: LCD Monitor Backlight - YouTube
? 6:06
https://www.youtube.com/watch?v=BTjH-jkuo9Y
Jan 30, 2014 - Uploaded by Heilman Hackatronics
This videos shows how to repair an LCD monitor Backlight. ... I've Samsung SA300 21.5 inch led monitor ...
How To Replace a LCD Backlight - Instructables
www.instructables.com/id/How-To-Replace-a-LCD-Backlight/
InstructablesHere are some simple instructions on how to replace a burnt out LCD backlight with a new working one to bring your LCD back to life. ... To get the the LCD screen and thebacklight inside, you must first disassemble the LCD housing; this is different depending on whether it is an ...
A (very) Simple LCD Backlight Fix - Instructables
www.instructables.com/id/A-very-Simple-LCD-Backlight-Fix/
InstructablesFix any broken LCD backlight with an ordinary light bulb and a dead CRT monitor.Broken LCD monitors basically come in three categories:1) Cracked LCD ...
Dec 30, 2015 | Samsung Televison & Video
How would I troubleshoot a black screen in a thunderbolt display?
> Is there a way to replace the backlight with OEM parts?
Yes, presuming that you don't electrocute yourself as you disassemble the unit, and that you have the correct tools.
> Or would I need to look into getting 3rd party LEDs to replace the current one(s)?
Not the correct part to replace. Instead, replace the "inverter".
Jun 13, 2014 | Apple Thunderbolt Display - LED monitor -...
Why would my HP laptop screen go black?
A few reasons
1) backlight burnt out (or broken)
2) loose or broken cable AND backlight burnt out (or broken)
3) Failed GPU (probably integrated into the motherboard on that model)
4) failed motherboard (same issue above)
Check by plugging in an external monitor- if you get a signal, your LCD need a new backlight (or inverter, an easy fix under $15 USD)).
Cheapest solution is to simply replace the backlight, but you'll have to diassemble the entire laptop lid/cover AND the LCD to get to the backlight at the bottom. (this could be under $20 USD to do). Often similar sized LCD's with different part numbers will work fine in different laptops (meaning, a 14" LCD mady by samsung or LG will be compatible with almost any same 14" LCD made by either, especially if it comes WITH the inverter!)...
:D
Sep 04, 2010 | HP Pavilion dv2000t Notebook
My backlight is broken (Casio EX-Z100)
Try to check on ebay, you may find the LCD with backlight just less than 30 bucks. To replace the LCD kit is easier to replace only backlight, and it's hard to find the backlight.
Aug 21, 2009 | Casio Exilim EX-Z100 Digital Camera
Hi, the backlight on my screen no longer turns on but i could see windows running so i know that the screen is not broken. i was thinking that the inverter is probably the problem, but if not how can i...
The backlight is normall part of the LCD panel assembly and is not normally changeable on its own (sadly) however here is a link to one being solf on ebay http://cgi.ebay.com.au/LCD-CCFL-Backlight-Lamp-for-IBM-lenovo-ThinkPad-X60-X61_W0QQitemZ250464679317QQcmdZViewItemQQimsxZ20090715?IMSfp=TL090715205001r13604
and here is a link to the X61 LCD dissassembly http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
After removing the LCD you will gently have to prise it apart to reveal the backlight assy. Hope this goes will for you.
Aug 11, 2009 | IBM ThinkPad X60 Tablet PC
I have a 32" LCD HDTV 1/2 of the screen is dark. SK32H2240S 5062580900051 Any suggestions? Where do I get parts to fix it?
1/2 of the screen being dark would usually signal a bad panel. A service center could check for U if it is a bad backlighting or the panel. Possibility that the panel may need replacing. Let me know how it turns out. You can check the website to see if you can get parts to fix it. Many tv makers don't seem to make parts available, desiring U to buy a new tv about every year. I would stick with the big name brands/Panasonic, Sony, Samsung./Big name brands are more likely to have parts available to fix a broken tv.
May 14, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
New laptop lcd display not working
check the panel to make sure the panels are the same model number there are more then one part number for gateway lcds for your model and if your laptop uses the xga screen and your not replacing with the correct panel then you will get the problem you are seeing now.even thought the inverter and back light are the same the panel are very differant.
Feb 18, 2009 | Gateway MT6451 Notebook
Broken Lcd newb questions.
It comes as all one unit...it is just a matter of getting the case apart, unplugging the LCD, plug in the new one...reassemble
Jan 27, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba blank screen
Your LCD backlight is not working. You will either need to get it fixed or have the LCD assembly replaced altogether. If your computer is under warranty, Toshiba will perform this repair. Otherwise, take it to a local service shop.
Jun 05, 2008 | Toshiba Satellite A135-S2276 Notebook
Broken backlight
  • Just get a new one
  • Buy one and replace it
  • Cry and ask your parents for a new one
  • Ask a fairy to fix it or Santa Claus
Oct 19, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Casio QV-3500EX Digital Camera Logo
54 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
