Question about Gateway MT6730 Notebook PC
Gateway MX6438 will not power on
Stopped working while plugged into outlet, flashed red light (indicating battery is out of power?) when trying to turn on.
After numerous tries of pressing power button, stopped flashing red at all.
Just bought a new battery 9 months ago
help!
If your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Posted on Dec 29, 2008
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
My television just doesn't turn on. It was working fine last night then it stopped working. The outlet works and the red light doesn't come on.
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now,the tv should be working again,if the tv still getting same result no power LED light indication at all or just flashing power LED light indication.Mean ur tv the power supply board is the causes and the problems.The power supply board,that board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Memorex MLT3221 32 in. LCD TV
Press power button and all you get is blinking red light. nothing comes on just black screen
Have you check the battery you are using or better still remove the battery at th back and plug it directly to the power supply and check if it turn on well . if it is positive then change the battery , the battery is at fault.but you can still add the battery when you see that after removing battery and plug it straight it power on then after like twenty minutes you can slot in the battery as well so as for it to be re-boost by the power and get charge up.
May 24, 2010 | Gateway MX6438 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Will not power up. trying to turn on and just the red battery light flashes
blinking red light with battery icon means that you are running out of battery power. if the computer is plugged in to the wall and it still does the same thing you may have to replace the ac adapter or charger. the charger should have a green light on it to indicate it is getting power.
Sep 29, 2009 | Gateway Computers & Internet
Won't boot up, fan comes on, power light but nothing else
Sounds like a hard drive issue. Take the hard drive out and put it back in again and try it. Hope that helps.
May 26, 2009 | Gateway MX6438 Notebook
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Have an MT6451. When I press the power button it will not turn on but the battery indicator light in front of the laptop flashes red every time I press the power button. I should also tell you that it did...
Gateway MT6451 laptop. That was easy but the rest is a guess without more details. It sounds like this computer is not plugged into an outlet or is not getting power from that outlet, and that the battery is dead low. Try plugging something else, like a lamp, into the very same outlet that the laptop is plugged into to make sure it turns on. Not the next plug over on a power strip, but the very same plug. If it doesn't get power either, there's hope. Except that your battery needs a good recharge after the laptop starts getting power.
If the outlet turned out to be good, then the power adapter on your laptop may have failed. At this point you'll need try another power adapter and try again. At this point you may need the help of people who can look at the computer for you, preferably friends with a similiar laptop (and power adapter).
I wish I could help more, but thats a start.
Mar 30, 2008 | Computers & Internet
Gateway MT6730 Notebook PC Logo
324 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
