Question about Bosch Thd2021gb Filtrino Fast Cup Hot Filtered Water Dispenser
Descaling instructions bosh filtrino fast cup
    New Friend:
It took me ages to get his to work - seems that on the THD2023GB (Black) Filtrino, you push and hold the temp. set button for 10 seconds to get he descale programme running.
Posted on Dec 22, 2012
  • Anonymous Feb 09, 2018
    Thanks! Yes, for my black Filtrino it is the TEMP. SET button that has to be pushed and held for 10 seconds to get this to work, *not* the on/off button as the Filtrino user manual says!
    New Friend:
From the manual, although I cannot get it to work.
-Turn the appliance off with the on/off
switch.
-Press and hold the start/stop button.
-Turn the appliance back on with the on/
off switch.
-Release the start/stop button as soon
as the DESCALE symbol lights up.
Running the descaling programme
-Remove the water tank, pour out any
remaining water, and reinsert it.
-Prepare the descaling solution according
to the manufacturer's instructions
and pour it into the water tank up to the
calc mark. A descaling agent approved
especially for this machine is available
from Bosch Customer Service (Article
No. 310967) or from specialty retailers.
-Place a container holding at least 500 ml
under the water outlet. The container
must fit the cup stand exactly and must
remain in place. Set the cup stand to the
lowest position.
-Press and hold the start/stop button for
at least 10 seconds to start the descaling
programme.
-The descaling programme will now
run automatically. The N icon flashes
while the programme is running. (The
programme runs for approx. 10 minutes).
The descaling solution is pumped
through the appliance in multiple phases
and then runs into the container until
the water tank is almost empty. A small
amount of solution is always left in the
tank.
-When the most recently selected
temperature icon lights up, the descaling
program has finished.
-Rinse the water tank thoroughly and fill
up to the max mark with fresh water.
-Now select and draw warm water three
times to rinse out the appliance. Do not
drink this water!
Posted on Nov 03, 2012
  • Gene Haynes Nov 03, 2012
    If you can't drink the water, use white vinegar instead of the descaler. Bosch descaler:http://www.amazon.com/Urnex-Activated-De...
  • Bosch Master
  • 5,353 Answers
Use white vinegar, and not CLR.
Vinegar is a food source that will not harm you, or harm kitchen drain, and also excellent descaler that will not harm metal.
You can even soak shower heads in white vinegar for several days.
Now the exact technique: I would fill affected area, and let sit for a while, pour out, then repeat with more white vinegar.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Sep 30, 2012
SOURCE:
Descale a showerhead
  1. What to do
    1. Unscrew the head of the shower from the hose. This may be quite stiff. ...
    2. If it is possible, unscrew the rose attachment from the shower head. ...
    3. Soak the parts in the descaling agent or white vinegar overnight. ...
    4. Reassemble the parts, checking that the rubber washer for the hose is in place.
Descaling shower head
Jul 21, 2015 | Water Water Heaters
Fill tank& descale keep flashing.
Fill the reservoir with white vinegar and run a cycle. Discard the vinegar and repeat the process a second time. that should remove the scale and reset the flashing light.
May 19, 2014 | Bosch TAS2002GB Tassimo T20 Hot Beverage...
Descaling bosch 125hx ng
no you do not, but it is a good idea to take the hydrogenerator apart and remove the waterwheel inside to protect it from damage(if you have anything that gets shot through the pump)
Connections are 1/2 inch.
Dec 09, 2013 | Bosch AquaStar Natural Gas Tankless Water...
Powerstar ae125 runs hot then cold in shower
Increase your flow, sounds like you are right at your activation rate.
1 way is to turn down the temp on the machine, so you dont have to mix in so much cold at your shower. Check to see if your mixing valve is bad, or your showerhead has restriction/scale built up in it.The other way is to turn on your lavatory fixture full hot before showering(which will keep hot water flowing through the machine as you adjust your temp to be comfortable.
Nov 24, 2013 | Bosch PowerStar AE115 Tankless Water...
How to descale a noritz tankless water heater
1) Copy following links for general descaling resources for Tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
2) Add a comment with what you discover
Jan 04, 2013 | Noritz 6.3 Gallon Residential Tankless...
Unit flashes the number 20
A 20 error code means the high limit switch is being tripped. This is most typically caused when scale develops in the heat exchanger. I'd recommend performing a descale on the heater to resolve the problem. Make sure to follow the instructions that came with your isolator valve kit.
Jul 10, 2010 | Noritz 8.4 Gallon Residential Direct Vent...
Sediment in lines -Bosch Tankless Water heater
I would recommend a simple sediment filter housing be installed on the main water line coming into the house. Material cost about $100. Have a plumber install a bypass loop so you can just shut off 2 valves when you need to change it. I always install one with any tankless heater as cheap insurance against such a problem. As far as adding something to clean the lines I would refer to the manufacturer's instructions and use only what they recommend in order to preserve your warranty. For a solar water heater I prefer Velux.
Please rate if this helps-
Mar 28, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch Thd2021gb Filtrino Fast Cup Hot Filtered Water Dispenser Logo
5,741 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Sheldon Dedek
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
