Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
KDF50E2000 TV TURNING OFF BY ITSELF THEN BLINKING 3 TIMES????
MY TV WILL TURN OFF ON ITS OWN THEN THE POWER LIGHT WILL BLINK 3 TIMES, IVE HEARD THAT THE REASON FOR THIS IS THE LAMP DOOR NOT BEING SECURELY ON, IS THIS TRUE?? I HAVE MADE SURE THE DOOR IS ON CORRECTLY AND IT IS SO CAN ANYONE THINK OF ANYTHING ELSE?? THANK YOU FOR ANY KIND OF HELP
    Novelist:
    Scholar:
  • 67 Answers
In this set, I have had door switches go bad. They develop resistance in the switch, not allowing the TV to realize that the switch is completely closed. Also, the lamp doors do warp, and I believe the lamp door for this set is not available anymore because of the amount of warped doors that are out there.
If you know the lamp is good, and the door not warped/is securely in place, it is either the switch, or the protection circuit itself. Any competent repair shop should be able to track this down and assist you in repair.
Hope this helps...
Posted on Jan 05, 2009
My 50" Sony Wega kdf50E2000
the lamp door cover is not secured properly or the lamp is not inserted correctly. Thats what the 3 blinks is indicating.
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
KDF 50E2000 WONT POWER UP POWER LITE BLINKS RED 3 TIMES THANKS
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 12, 2011 | Sony KDF-50E2000 50" HDTV
What does theblue light mean when its blinking
the steady, blinking blue light means it is working. If the light blinks quickly, ususally 3 times, then it is either turning itself off or turning itself on. if you're getting a steady blink, try holding the button down long enough for it to flash rapidly 3 times in succession. after that, it should blink no more, because you have just turned it off. Want to turn it back on? hold the same button down until it flashes rapidly 3 times again, and you have just turned it back on.
Jan 23, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
My sony kdf50e2000 power led flashes 3 times then pauses then flashes again...and so on.
I hope you recently tried to replaced lamp in TV. 3 times blink shows that Lamp cover is not securely attached.
Please check Lamp cover.
Apr 01, 2009 | Sony KDF-50E2000 50" HDTV
No Power
It's possible your TV when into protection mode. This happens when a part is burned out inside your TV to prevent further damage.
Try unplugging your TV for 30mins. Then see if the problem still occurs.
If the problem is still there, you may have to take it to a repair shop to diagnose the problem.
Feb 09, 2009 | iLO LCT32HA36 Television
Tv does not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jan 02, 2009 | Akai LCT3201AD 32 in. LCD Television
Sony - Projector TV won't turn
Sony TV;s will give a service code, count the blinks, eg; 2-6, light will blink X amount of times, hesitate & blink again so many times. Count and report back but, I would recomend to unplug the TV's power cord, to reset the TV's system. Unplug for at least 3 minutes. I hope this was helpful.
Jun 11, 2008 | Televison & Video
Astar LTV-2701 27
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
Jun 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
TV turns off by itself after being on for 60 seconds
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Hope this helps.
Jan 13, 2008 | Toshiba CN36X81 TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
295 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
