Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
I cant get power is my harness missing wires?
I wiring harness has a yellow and black and remote wire the rest are speaker wires.. am i missing a red wire because when i put the yellow to power and ground the black im no getting anything. wat am i doing wrong.
    Problem Solver:
  • 6 Answers
Yes, your red wire is for ignition, yellow wire is for battery and black is ground. The red ignition wire is for the radio to turn off and on with the ignition. The yellow is always hot, for memory.
Posted on Dec 29, 2008
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
Jul 02, 2011 | Hyundai Motor 2003 Elantra
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
Stock 1995 Jeep Wrangler stereo wiring harness missing/cut off.
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Apr 09, 2009 | 1995 Jeep Wrangler
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Dec 28, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
I need to know what colors mean what, so i can hook my cd player up
Red - Power
Yellow - primary power must be joined to the red
blue - Remote
Black - ground or negative
To find your speaker wires check the color of the cord behind each speaker than match it with the same color in the dash.
or the easy way is to use a normal 1.5v penlight battery and try each speaker cord behind the dash and listen to which speaker give off a crackling noise so you can get the balance on the cd player right.
If u trying to find power in the car and don't have a tester than get a 12v light or bulb join the negative to the body and push the positive wire into each one of the holes in the factory plug in the dash one at a time until the light comes on. That is your positive the rest is easy. (DIY guru)
Oct 09, 2008 | 1991 Honda Accord
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
137 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
