Cars & Co Gas Scooter Part 33cc 36cc 39cc 43cc 49cc Coil Logo
Dexter Broussard Posted on Sep 30, 2012
My coil for a lexus ls400 1992 is not fireing to start the engine?
I change the coil and now i cant get to spark from it? what should i do?
Anonymous
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 14 Answers
  • Posted on May 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Night Owl:
Answers
14
Questions
0
Helped
3718
Points
16
Check ignition fuses. I think there is a rollover switch that shuts off fuel an spark.look in owners manual for it.or possibley got a bad coil have had many new bad parts befor....
1helpful
2002 Lexus LX 470. Crank but no start, I've changed the battery and spark plugs and ignition coils and it still will not turn over. I need help please.
You say 'Crank, no start', but you also say 'it will not turn over'. They are the same thing, if it cranks, it is turning over, but not 'firing' or 'starting'.
After you disconnected the battery, did you reset the Security System and Engine Immobilizer? You know it has one, that flashing light on the dash?
Some ideas here
https://www.google.com/search?q=2002+Lexus+LX+470.+Crank+but+no+start
Anti-theft Reset
https://www.google.com/search?q=2002+lexus+lx+470+reset+security+system
If that doesn't fix it, an auto electrician with a $5,000 professional grade Autel scan tool will be able to diagnose the entire car in 30 minutes. A $130 scan tool is garbage.
https://www.google.com/search?q=mobile+auto+electrician+near+me
2answers
98 ford ranger supercab xlt 2.5 spark plug wiring diagram
I will read the SM service manual to you now.
firing order 1,3,4,2
most cars with old coil packs 4 cylinders is just one pack
not coils but yes 2 coils in 1 pack run 4 cylinders, using wasted spark tech.
oops this old dog run 8 spark plugs now that is different.
and here it is from the book
we do know 1 and 4 fire as one and 3 and 2 first as one pair too.
I sure hope the 2 coils fire, the same way.
no lag. coil 1 spark 1, to coil 2 spark 1. hummmmm
yes tricky see these sage words. from the SM
Dual Plug Inhibit (DPI) is a function of the powertrain control module that is used when the vehicle is being started. During engine cranking, the powertrain control module will only fire the spark plugs on the right-hand side of the engine.Whenthe engine has started, the powertrain control module will start normal twin-plug operation.
Firing order and how the coil knows when to fire. I get spark but I cant get it started. Why?
Could be timing problem , timing belt or chain . The spark isn't happen at the right time . What make , model , year vehicle ? Engine size. The coil fire's when turned on by the PCM/ECM - engine computer , PCM/ECM knows by input from the crankshaft position sensor .
It mayI have no fire going to the coil or from the coil to the plugs
Have you checked the wiring, the spark @ plug, Power to the coil???
Engine Won't Start No Spark - Auto Diagnosis Repair Help
aa1car.com/library/no_spark.htm
If your engine cranks normally but will not start because it has no spark, or it ... If an engine has a coil-on-plug ignition system with no plug wires, remove one of ...
No-start, No-Spark diagnosing simulated - YouTube
? 5:13
https://www.youtube.com/watch?v=XSWN1M8Hoqo
May 19, 2010 - Uploaded by FrankHurtAuto
Simulation of no start with no spark diagnosing, ... Ignition coiland module test with test light (ScannerDanner Premium lecture) - Duration: ...
getting fire from coil but not to plugs - CarGurus
www.cargurus.com > Questions > Dodge > Ram 1500
CarGurusJun 12, 2013 - 2000 dodge ram 1500 4x4 not getting fire changed distributor cap, coil, pickup ignition, rotor, plugs, plug wires 2 answers. ... 1994 dodge 5.9 just shut off and wont start back up there is no spark or fire from coil or plugs. ... 94 dodge van 318 eng will not start new plugs new crank ...
Ignition Coil Troubleshooting: (No) Fire in the Hole
www.secondchancegarage.com/public/coil-troubleshooting.cfm
3helpful
3answers
1az engine noah cant start due to no spark
It sounds like coil packs one and two are bad. Try swapping coils two and three and see if there is any difference.
My bmw 1.6 e36 has lost its spark i have changed both crank and cam sensor could the lambda sensor still be the fault
Hi Thomas, You seem to have attended all that is required for the spark. Check the wiring and if it's fine I would suggest you have a diagnostic scan carried on on the vehicle. That will pinpoint the problem and allow a long term fix. Regards John
2003 lexus rx 300 engine diagram
i have a lexus es330 and i need to know my firing order of the spark plugs on this car. i got a read out p0354 coil misfire in 4. i need to know if its in the front or the back. thanks
4helpful
2answers
1993 lexus 300 sc firing order and distributor cap diagram
Hello! If the engine in your vehicle is the 3VZ-FE...The firing order is 1-2-3-4-5-6...Distributor rotation is Counter Clockwise...
If the engine is a 2JZ-GE...The firing order is 1-5-3-6-2-4...Distributor rotation is Counter clockwise
Guru...........saailer
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
1helpful
Lexus 2002 RX300 - What is it when the Trac Off, VSC & Check Engine lights are on and the DTC code says cylynder 1 and 6 misfire
You could have a bad coil pack or a bad fuel injector. swap out the coil packs from the misfiring cylinders and put them in the cylinders that are known to be firing correctly to narrow it down to determine if it is the coil pack first. When is the last time you changed the spark plugs? Pull them out of the misfiring cylinders to check the condition of the plugs.
Replced the cap & dist coil pac has fire no spark to spark plug
install the new rotor, if that isn't it check the crankshaft position sensor.
Top Cars & Co Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Cars & Co Expert? Answer questions, earn points and help others
