Question about Bose QuietComfort 2 Consumer Headphones
My Bose QC2's are making a woofing/garbled sound.
  • 20 Answers
Make sure this is isolated to the headphones by trying them with other devices/trying other headphones with the original item that caused the issue. Make sure you use different music files as well.
If it is still the headphones then it is a cable fault, the only place I know where to get them is direct from Bose so give them a call.
Posted on Dec 31, 2008
Woof woof noise from samsung french door refrigerator
it has a technical problem you should call the freeze fixer.
Mar 20, 2013 | Samsung 23.0 cu. ft. Counter-Depth...
Raven01@Hi, The left hand speaker has snapped off the head band on my bose qc2. Also, the blacl plastic that hold the headband together above the right speaker is coming apart. Can I buy a replacement...
No, Bose doesn't cover any damage done to products that is any fault of the buyer. You might be able to if you contact a Bose retailer and special order it through them. Just a note, it will cost you more for the new speaker due to it being a special order. Probably around the lines of 40-50% of the original sales price (which is outrageous). If I were in your shoes, I'd try to find the same unit on craigslist or Ebay.
Jun 18, 2011 | Bose QuietComfort 2 Consumer Headphones
Had new pads installed in the front and rotors were turned. Now I hear a sound as if one of the brakes pads touching the rotor. It stops when I bearly apply the brakes. Sometimes If I ride the brakes It...
Without going into all sorts of detai,l of
how brake work should be performed
I will say something wasn't done correctly &
you need to go back and find out what
I would guess that no rust was removed from
any components, and you new machined rotors
do not run true
You really need to do all you own vehicle work,
if you want to avoid this sort of poor professional
work, that is all over the industry
Mar 26, 2011 | 2002 Mercury Sable
Hi My QC2 had the sound off ...No idea what happened. Is there anyway to fix it? Tks Lewis
There is no common fault with these headphones, the fact that both channels are off at the same time means it is highlyunlikely that the transducers h or a connection in the plug has failed. That leaves the battery, battery connections and the circuit board. Due to the construction of the board there are no user reviceable parts so if it isthe board bose will have to replace it, therefore all you can do is make sure the source is ok by using some other cans, use a fresh battery and make sure the battery contacts are reaching the battery. Finally it is possible that the switch has failed but if that was the case moving it around would cause th intermittentlye phones to operate If you checked all that and no joy i'm afraid it's back to bose.
Mar 03, 2011 | Bose QuietComfort 2 Consumer Headphones
Won't turn on after swapping battery for a new one, it had crackling in both earcups but now it's completely dead.
It sounds like a battery problem.
Check to see if the battery is installed correctly.
Take it out and put it in again, and see if it works.
Try a another battery that you know is good.
If you have any way of testing the battery do it.
If the crackling was happening before you changed the battery you may have another problem, otherwise a sick battery is more probable than the earphones dying at exactly that time.
Jan 31, 2011 | Bose QC2 Headphones
Bose QC 2 Noise Cancelling Headphones the red light is on. Should there be a green light if they are working?
No green light for QC2, just red. If it's constant the battery is charged, powering the noise cancellation, and, if connected to an audio device, conducting sound. If the red light is blinking, the battery is losing its charge.
Nov 18, 2010 | Bose ® QuietComfort® 2 Acoustic...
Right earphone shorting out
Good morning,
I would start off with calling Bose they do have a good warranty program and would help you.
Sep 21, 2017 | Bose QC2 Headphones
When light button is pressed, there is a woof noise
guess what / your right / have a chat with the co that sold it to you . I d let the woof out of the freezer and then it would weigh less and the drawer would slide easly . problem over .. , not quite . this is a quality product and you should expect it to be . draw's should be smothe ect . look for damage to outside and frame if found have them replace it . mm
Jan 16, 2010 | LG LDC22720ST Stainless Steel Bottom...
My QC2 right headphone starts to buzz, like a vibrating sound
It is a blown woofer in the headphones that is causing the vibrating. Because when a woofer is blown is will develop a small tear, this tear will get bigger over time and cause that "vibrating" sound that you hear. Lucky for you joenfrancis your headphones are still under warranty so they will replace the headphones for free. Hope this helped!
Feb 20, 2009 | Bose QuietComfort 2 Consumer Headphones
Audi A6 2.7T Quatro 115K
It may be a wheel bearing going bad. The A4 is known for wheel bearing issues, and the A6 shares many drivetrain parts with the A4.
Jul 26, 2008 | 2001 Audi A6
Bose QuietComfort 2 Consumer Headphones Logo
388 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
