Question about Uniden BC248CLT Base Scanner
Bc560xlt it only picks up the weather and nothing else its still programmed but nothing picks up anymore. should I reprogram it or what and how do I reprogram it?
  • hillabeans77 Jan 04, 2009
    Thank you very much!
  • 379 Answers
heres the owners manual , it will guide you thru reprogramming and trouble shooting .
Posted on Dec 31, 2008
  • Rick Byrd
    Rick Byrd Jan 03, 2009
    follow up - was this information worth a FIX YA vote ? thanks for voting ! .
I have a Uniden BC560XLT police scanner. I don't know how to use it.
Why not go to the Uniden website for information. You may be able to download a copy of the manual for your scanner or get some basic information regarding programming
Apr 05, 2013 | Radio Communications
How canifixmyscanner,it scansbut doesnt pick up program stations
You didn't provide the make or model of your scanner, or any real specifics on your problem, but your first step is to make sure that you've programmed active frequencies into it. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
For a functional check, you should first program and scan NOAA weather frequencies to verify whether or not the scanner is working properly. Many scanners have a WEATHER or WX band function that will let you check the NOAA broadcasts without any programming. If your scanner does not pick up the weather broadcasts you may have an antenna problem or an electronic problem that will require professional repair.
Bill B.
Listening in since the 60's
Jan 18, 2011 | Radio Communications
Can't get the weather report to come on-can't find my insructions to reprogram it to pick up local noaa
You can reprogram it by doing the following:
1. Turn switch on side of radio to "ON".
2. Press "MENU".
3. Press "UP" arrow until "CHANNEL" is displayed.
4. Press "SELECT".
5. Press "UP" arrow until you hear the broadcast of your station.
6. Press "SELECT" to save station selection.
7. Press "MENU" to close menu mode.
To turn Weather/Hazard broadcast on again, press "WEATHER/SNOOZE".
Jan 13, 2011 | Midland WR-100 Weather/RDS Radio
How to program my BC560XLT
The factory manual should answer all of your questions. You can download and print it, free of charge, here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
Aug 01, 2010 | Uniden BC350C Base Scanner
Uniden 30 ch scanner i have locked out all channels.
Each channel with the zeroes means that it is a blank - with nothing programmed into it. Going to any one of them and programming a frequency will get rid of the zeroes and switch off the lockout. It's picking up weather, so it's working. Sounds like you just need to find and program active frequencies for your area, and the place to find them is:
If you need it, you can download and print the manual for the BC60XLT-1 here:
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
Owners manual for a uniden bearcat bc560xlt scanner
manuals can be found at amazon, click here and take a look: Amazon com john deere lt133 manual. I hope this was helpful. Cheers
Feb 03, 2009 | Audio Players & Recorders
Keyless Entry won't work when it's cold
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't get my BC560xlt to accept a program
Internal problem, can be repaired by a tech familiar with Bearcat scanners, but probably not worth the cost. If you're near NJ, call 973-831-5900.
Nov 03, 2008 | Uniden BC248CLT Base Scanner
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Apr 30, 2008 | Uniden BC60XLT-1 Handheld Scanner
How do you program a bc560xlt scanner
Hello sir,
Check out this link for the programming...
Good Luck
Don't forget to rate the solution
Mar 11, 2008 | Audio Players & Recorders
Uniden BC248CLT Base Scanner Logo
692 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
