Question about ASUS M2N-MX Motherboard
The installation is starting then failure
Sound drivers
    President:
  • 2,351 Answers
Hi ravishan12, from time to time windows just fails to install driver software correctly.
(Not uncommon). There's more than one way to get your sound driver software installed.
Make sure the bios is set, AZALIA AUDIO [Auto]. See page 2-22 in your manual.
Though I know you have an Asus CD with the sound driver on it, I don't want you to use it.
Create a folder on your desktop & name it "Sound". Go to Asus & download the sound driver into your "Sound folder".
Click on this Asus M2N-MX link & choose your operating system, than click on "M2N-MX related files for download". Click the plus sign next to Audio & download into the Sound folder.
http://support.asus.com/download/download.aspx?SLanguage=en-us (2007/04/19 update).
The file will be in .zip format. Open the Sound folder & uncompress the .zip file - keeping the uncompressed files in the same Sound folder. Once uncompressed there will be two folders. One 32bit & the other 64bit. (This refers to your operating system) Windows 32bit or Win 64bit).
If you do not have the program, "Winzip" to uncompress the .zip file you can download it for free at this next link: http://www.download.com/WinZip/3000-2250_4-10003164.html
Next, how to get windows to install your sound driver software without failing. Open windows device manager. Scroll down through the list of icons. You should find that Sound, video and game controllers is already opened.
Right click once on the explanation point, a window will open & Left click once on “update driver”. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Left click on the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find the “Sound” folder on your desktop. Open it, high-light by left clicking on it once the correct folder, 32bit or 64bit. Than click OK.
Windows will search within the folder & install the correct driver software. If by some chance windows does not, repeat the above & open the Sound folder. Find the “AsusSetup.exe” within the correct 32bit or 64bit folder & click on it once. Than click, OK. Windows should install the driver. Close all opened windows & restart your system. Test you audio by running “SoundMax" software within control panel”.
Good luck ravishan12!
Mike
Posted on Dec 29, 2008
I hav intel dg31pr boad whose audio drivers are not getting installed............every time it says failure.......wat shud i do?
you might have to uninstall the sound drivers resart your computer then reinstall the sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
hope this helps
Jun 04, 2011 | Intel DG31PR Motherboard
"install HD audio driver failure"
there is a trick of installing hd audio.Remove all the drivers.
First install the patch of winxpsp2 , it should be in ur driver cd somewhere in audio folder.
then remove it. Again install it and then install sound driver and all other drivers.
It will definitely work.
Jul 06, 2009 | Intel DG31PR Motherboard
(scanner failure) and flash top lighet
the printer can't saw the scanner driver that's why the motor that or servo make a sounds.. or your scanner driver corrupt..
you need to uninstall you current driver
and then restart your computer
...and then install again ..
May 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Install realtech audio driver \ failure error code OXE000227
that sounds pretty ***. maby you should stick to game boys or super nintendos, sumthing **** like that :)
Jan 16, 2009 | Audio Players & Recorders
Audio driver not installation failure
if your sound card is in-built try installing from the motherboard cd you got..if then also it says some problem then try for the driver software in internet then too problem continues try installing the OS again..
Sep 24, 2008 | Intel Computers & Internet
Sound Driver Installation Failture
go to systemaxpc.com look up your driver on the downloads page. download it and save it. open the zipped file look for setup and viola sound
Sep 24, 2008 | Microsoft Windows XP Professional With...
D945gcnl
Why because some audio drivers may not be properly installed even it is installed from the motherboard drivers. why because some Bios doesnt allow this. only solution to solve this issue. Try downloading latest driver for your sound card model.
thank you !
Dec 20, 2007 | E-Mu 0404 Sound Card
Sound problem with d945gcnl board
installing same drivers from product cd-rom does not clear the driver issues. why because Bios does not support same driver re install in case of audio. this is normal. Download latest updated driver for your sound card model. thank you !
K7s5a sound driver
Hi, Code 10 refers to device not starting which can mean either hardware failure, corrupt drivers or wrong driver. The K7S5A uses either an SiS 7012_111 or an CMedia AC97 depends on the audio chipset installed in your motherboard version. Google for the necessary drivers and try which ever will work. Good luck and kind regards.
Sep 28, 2007 | Computers & Internet
ASUS M2N-MX Motherboard Logo
183 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
