Replaced alternator still not charging only putting out 12.5 volts had alternater bench tested putting out 14.25 volts need a wiring diaagram for charging system
1998 trooper new alternator and still not charging and alternator bench tested good,
Check main 80 amp fuse in engine compartment and also check fuses in inside fuse box, there two in that one. first is engine fuse 15amp and the 10amp gauge fuse,
Here is the wiring diagram for the charging system as you asked for , also check connections, follow battery wire off the back of alternator make sure connections are good , that wire runs to engine fuse box and that is one fuse that i said to check it is 80amp, hope this is helpful good day
SOURCE: Intermitent problem with alternator not charging. 1998 Cherokee 6
2 possibilities, a bad wire somewhere (a break in wire) that's causing this, or a defective gauge. How often does it go to 0 volts? If you put a load on system when it drops to 0 volts (lights on, a/c on, hit the horn) does everything seem normal? If it does, it must be a bad gauge.
SOURCE: alternator belt diagram 1992 Isuzu trooper
1. Remove battery terminals and secure them away from the battery posts using nylon wire ties.
1a. Fine some comfortable eye glasses (clear or yellow) and keep them on. There are plenty of opportunities to get debris in your eyes during this procedure.
2. Spray "PB Blaster" (loosens bolts) on two bolts that secures alternator.
3. Jack-up vehicle on side to access alternator. Use a jackstand to support.
4. Using a 10mm open-ended wrench, loosen the bolt that swings the alternator. Screwing the bolt "in" or toward the engine will allow play to increase in the alternator belt. Loosen the 12mm bolt slightly next to the 10mm bolt (approximately 1.5" toward engine).
5. Continue to loosen 10mm bolt until there is enough slack in the belt to remove the belt from the alternator pulley.
6. Remove belt. It may be possible to remove belt without removing fan faring. Maybe not. If not, you will need to remove plastic fairing. If you must remove fair, go below fan fairing and disassemble connectors that hold together pieces of fan fairing. Carefully remove.
7. Install alternator fan from above.
8. Check that alternator belt is on all tracks (from below with a flashlight), and slowly tighten.
9. Secure 10mm and 12mm bolts. Recheck tightness.
10. Reassemble battery connection and run vehicle at idle for about 5 minutes. Check belt for proper tension.
11. CAREFULLY check tension of belt. Or disassemble battery connections and re-check belt tension.
12. Reassemble fan fairing (if not already assembled), re-connect battery terminals, and have a nice day. :-)
SOURCE: Bench Test explorer 1998 rear wiper motor
power is wht/or & blk/blu. to make the wiper move both left and right across window, it alternates positive and negative polarity.
SOURCE: 1998 Monte Carlo alternater not charging
Ok, i understand that you have replaced the alternator, but there seems to be a non charge state in this case. i recommend checking the charging system. use the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a +positive terminal (red), - negative terminal (black). The battery in this illustration has a protective cover over the positive terminal to prevent short circuit in case of an accident. Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use. (Note: never disconnect the battery while the engine is running. If the battery cable is disconnected from the battery a spark can be generated which can cause the battery to explode or a major electrical malfunction to occur.)
To check a battery surface voltage, remove the positive terminal protective cover. Connect the +positive side meter lead (red) to the positive side battery terminal. Connect the - negative (black) side meter lead to the negative battery terminal. With the vehicle not running and the car sitting over night the battery voltage should be between 12.5 and 12.8 volts.(You will need to use a voltmeter for this testing procedure)
The alternator is rotated by a drive belt driven by the vehicles engine while it is running. Electrical voltage and amperage are generated to recharge the battery and supply voltage to the electrical system of the car. The alternator is held in place with mounting bolts. There is a main electrical wire on the rear of the alternator that supplies voltage to a main voltage junction box. If your alternator is not charging properly, your battery will slowly drain down from operating all the electrical systems in your car and stop the car from running.(most non charge states will be the cause of a loose belt or a low tension rate, due to a mis-adjusted alternator. make sure you have enough tension in the belt for full rotation of the alt pulley)
Next, you will need to check the alternators output with the Amp meter.
Testing the amperage output of the alternator is good for measuring the amount (not the level) of voltage the alternator can produce. This test can be tricky because if the alternator is weak it can still show it as producing amperage. Which is good, but if the voltage is low, it will still allow the battery to go dead. To check the amperage output of an alternator an amp meter is needed. Once the meter is connected start the engine. Next turn on all electrical accessories and raise the engine idle to about 1200 RPM. The alternator should output the max amperage it was designed to produce. Example: a 90 amp alternator should output about 88 amps. Note: An alternator cannot sustain maximum output for long periods of time. If the alternator is forced to operate at maximum output it will overheat and fail. An alternator is designed to operate at max amperage output only for a reasonable amount of time.
((Connect the voltage meter lead the same way you would in a battery static voltage check, Start engine (do not drive) at engine idle the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing.)))
SOURCE: just replaced alternator on 1998 Isuzu Trooper.
There is a charging relay thats blue and sits in the engine bay fuse box .
This can often fail and give the signs of a duff alternator .
