Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frig is hot only in upper front (divider) where two doors meet.
Have tried cleaning vents, etc.
  • robyno Dec 29, 2008
    Fan is running and no frost in freezer, any other suggestions?
  • 115 Answers
Need to see if your fan is running in the freezer side if not replace it if it is then check to see if you have frost on the back lower wall inside the freezer if you have frost then you have a defrost problem
Posted on Dec 29, 2008
  • Steven Carter Dec 29, 2008
    what brand is it if it is a ge or samsung it is probably the main board which is on the back of the refrigerator and most any other brand the problem will be the relay on the compressor
Gasket between frig and freezer is darkening due to very hot surface on divider between sections
If it is that hot you really need to get this checked out ASAP. It could become a fire hazard.
Mar 12, 2014 | Admiral Refrigerators
The refrigerator side is not cooling though the freezer section is working.
Check in the frig side upper left at the top. The frig has to be running. There are air vents that bring the air to the frig side. If you dont feel any air this is what could be the problems with that:
Freezer fan not running
vent is closed
vent is iced up
evaporator is iced up
try to determine which one of these it is or not...
let me know and we will go from there
hope this helps
Mar 30, 2010 | KitchenAid Architect 25.3 Cu. Ft....
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Aug 01, 2009 | KitchenAid KSCS25IN Side by Side...
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
No air movement in frig and does not cool or freeze
you need to get a tech to look at it it sounds like a sealed system issue Compressor,drier etc....
Nov 12, 2008 | Maytag MFD2560HES Bottom Freezer French...
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
