Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Incorrect region codde
dipti on Apr 27, 2007
some dvd's aare not getting played its showing incorrect region code please help me
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Feb 28, 2009
-   when ever english DVD is put it shows wrong region why?
and how do i rectify
-   Guest
Feb 12, 2009
-   Any time i put in a dvd it would dvd then incorrect region code right under it
-   mafia leader
Feb 02, 2009
-   wrong region says my dvd player
-   Guest
Aug 31, 2008
-   changing region code-   galgaligiris
Aug 30, 2008
-   I need help. I gdo not know where to find the region codes on the computer.
-   madeah
Best Solution
posted on Jan 11, 2008
Very Helpful)
murderface
Rank: Guide
Rating: 92%, 20 votes
Press setup, go down to the lock symbol. do not enter it, just have it highlighted, then press "0" seven times. this will make it region free. also applies to most LG DVD players and DVD recorders. Hope it helped, murderface.
Was this helpful?
Yes
No
Solution #2
posted on Oct 27, 2008
Very Helpful)
serkanizgi
Rank: Apprentice
Rating: 96%, 5 votes
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 18, 2007
Helpful)
pseudonym
Rank: Master
Rating: 88%, 56 votes
Many customers want to play DVDs from other countries, or that they bought overseas. Our DVD players will ONLY play dvds from Region 1. On the back of the DVD case, there is a small symbol, it is a picture of a globe with a number on it. That number MUST be 1, or 1-5. If it says anything else, that DVD cannot be played. It also states this in the manual. Customers may ask how to change the region code in our players. We cannot advise them how to do it, and as far as Samsung has informed us, you cannot change the region code. Other players may have this ability, or they may say they can find this out online, but we dont know how to change this, or if its even possible. Refer the customer to a dealer to inquire about multi region, or region-free DVD players, which Samsung does not make.
Region codes prevent DVD players bought in one geographical region from playing DVDs bought in other geographical regions.
There are 8 regions (also called "locales"). Manufacturers usually mark players and discs with the number of the region with which they are compatible, superimposed on a world globe. DVD players have only one number. Discs can have more than one or, in some cases, none. Discs with no region code numbers play on any player in any country.
A DVD player's region code is incorporated into the firmware of the DVD player by the manufacturer. It cannot be changed by the customer.
A list of region codes and regions is below.
REGION CODE REGION
1 USA, Canada
2 Europe, Middle East, Japan, South Africa
3 South Korea, Taiwan, HK, ASEAN
4 Australia, NZ, Latin America
5 Ex-Soviets, Indian sub-continent, Africa
6 China
So your next question will be, can I change the region code?
DVD movies have region codes, and they typically only play on a player or DVD-ROM drive sold in the country where the DVD movie was sold.
The DVD player or drive has a region code in its firmware. Personal computer DVD-ROM players often have the code in the software or MPEG-2 decoder. The two codes must match for the player or drive to play the movie.
Region Codes cannot be changed by the end user. Doing so will result in firmware damage.
Was this helpful?
Yes
No
Solution #4
posted on Jan 03, 2008
Somewhat Helpful)
manugolf
Rank: Master
Rating: 78%, 16 votes
you can change your region codes some do it easy some a little more complacated i will give you some weg sites that are free to use no fee like most http://www.regionfreedvd.net/player/pioneer.html
http://www.regionfreedvd.net/player/samsung.html
these are just for two make but if you change name of make in web address to your model will be able to find yours.
Was this helpful?
Yes
No
Solution #5
posted on Sep 09, 2007
Somewhat Helpful)
vinzee
Rank: Apprentice
Rating: 64%, 37 votes
i think ur dvd is older virsion,, in case u change region ,i hope it ont work,for all disc,, not worth.
Was this helpful?
Yes
No
Solution #6
posted on Nov 09, 2008
Not Rated)
tejpatel79
Rank: Apprentice
Rating: 0%, 0 votes
my philips dvd player show me this error
wrong regional
please help me
Was this helpful?
Yes
No
Solution #7
posted on Sep 18, 2008
Not Rated)
ronaldnicola
Rank: Apprentice
Rating: 0%, 0 votes
I have a Samsung E136B DVD player purchased in Dubai, I need the country codes to enable me to view Imported DVD's - pse assist.
Was this helpful?
Yes
No
Solution #8
posted on Jan 06, 2008
Not Rated)
Bluehound
Rank: Master
Rating: 83%, 40 votes
Try http://www.dvdexploder.com/how.htm
Costs $10 but well worth it.
Region codes can be changed on most DVD Players without any harm to the player. They can also be changed on PC players but if not small software programs can be found on Google that change the region for the dvd that is being played.
Was this helpful?
Yes
No
Related Problems
the dvd runs but there is no sound. I have replaced the cord...
it says bad disc on all movies we try to play
By mistake I clicked on progressive scan from menu >...
sound is barely coming from the tv with volume turned...
Can you Help with these DVD Player problems?
My DVD player Philips 3007/69...
Solve
My DVD player Philips 3007/69 door won't open. There is a disc in and I am able to play the disc. ... (More)
philips dvd player model #DVP 320
Solve
We bought this philips dvd player model #DVP 320 about 2-3 years back, and now it is not working,... (More)
I lost my remote to my phillips dvd...
Solve
I lost my remote to my phillips dvd player molder no dvd622/37 need new one
password request
Solve
my dvd, is asking me for a password. there is an option to change my password but i need to know the... (More)
t.v screen says unusable signal but...
Solve
I am getting sound but no picture. have changed all the cables with the same results...sometimes it... (More)
23 Other Users Have The Same Problem - Continued
Comment by madeah, posted on Aug 30, 2008
I do not know where to go on my pc to change the region code. Please help!
Comment by curt1218, posted on Aug 04, 2008
my coby 227 dvd player says wrong regional code. it never said that before
Comment by Guest, posted on Aug 04, 2008
Comment by sherrie1, posted on Jul 28, 2008
Ive bought a dvd from U.S.A and need to have the region code so I can play it. Model number is Sharp DV-SL10, serial number is 304922708. Could you please help me to crack this code, thanks
Comment by Guest, posted on Jun 24, 2008
aparece en la pantalla invalid region
Comment by dylanmate, posted on Jun 11, 2008
need regional code for standard lg dvd player
Comment by oysterman62, posted on Jun 08, 2008
how do i change the region code on my symphonic-wf 802 thanks for any help
Comment by subsailor, posted on May 09, 2008
I HAVE A DR-MX1S AND WANT TO MAKE IT MULTI REGION,
CAN ANYONE HELP WITH CODES PLEASE
Comment by lew henn, posted on Mar 24, 2008
PLEASE ASSIST ME, I NEED TO CHANGE THE REGION CODE ON MY DVD PLAYER MODEL DVP3146K. THANK YHOU
Comment by Guest, posted on Mar 17, 2008
i want to change region code on my dmres30v combo can any one help please,i have an allforone remote,thanks,
Comment by Guest, posted on Feb 23, 2008
Some DVD players do not play DVDs recorded on my LVW 5006 recorder. How do I set regions?
Comment by musicaly, posted on Feb 12, 2008
A dvd from mexico that I bought to work on my spanish won't load. I want to know how to change the region code of this player
Comment by Guest, posted on Jan 17, 2008
region code unlock?
Comment by srima, posted on Dec 18, 2007
i have the same in correct region code for my audiovox dvd player
i have the same problem of wrong region code for my audiovox d 1917 dvd pleyer
Comment by the master, posted on Dec 05, 2007
need the codes to unblock de region
Comment by shelldean, posted on Nov 29, 2007
Lost the original remote to Philips 622 dvd player and some how the region code was changed, now it just says incorrect region code and cannot play anything. How do I change with a universal remote?
Comment by Jools15470, posted on Nov 08, 2007
I was wondering if you have any unlocking code for my JVC DVD Player - XV-N212, as I'm struggling to find one.
Sponsored Links
Describe your DVD & Video problem:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
DVD Players
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
