Question about Kenmore 22422 Top Load Washer
Kenmore 110.22832100 makes clicking noise
The washer stopped spinning and just makes clicking sound. I suspect it is a bad belt. Would that be correct? How can I remove the back to check it out and possibly replace the belt?
  • mexarican209 Dec 31, 2008
    same problem with the model 110. 92586210...
    Problem Solver:
  • 7 Answers
It sounds like ur coupler there are 2 screws on ur control panel remove them flip it up remove the shell clips on each corner remove shell down in the front of the unit behind the pump and motor is the coupler 4 clips total 2 remove pump and motor 4 dollar part 3 pcs hope this helps
Posted on Jan 07, 2009
Hi, May tag Washer LA 712. It won't go into spin cycle, unless I force it hard, then it spins fine. It is not making noise when stopping. All else works fine. I suspect a sticking break. ?
Sounds like either b bearing or a belt going bad. I would have it serviced. It could be your computer plate but it wouldn't be responding at all.
Apr 25, 2017 | Washing Machines
Once it goes to the last spin cycle ,( the fastest one) it starts making a thumping sound . could it be a belt or bearing?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 13, 2011 | Kenmore HE2 Plus Front Load Washer
Doesn't spin all the water out
sounds like the coupler that connects the motor to the transmission is going bad.  A $20 part
Mar 30, 2009 | Kenmore 24902 Top Load Washer
NOT SPINNING ONLY CLICKING NOISE
sojnds as if you have a bad motor coupling, this models equivelent of a belt, you can search you tube for a video as to how to replace it not that bad, seacrh "kenmore motor coupling"
Jan 25, 2009 | Washing Machines
Clicking sound.....
must likely something in between drum & basket or rear bearing going bad.call sears ask for service smart agreement it will cover rear shell with bearing &basket in warranty
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
240 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
