Question about Philips 30PW850H 30" TV
Green screen for several weeks i had about a dozen thin green lines at a slight angle going across my screen, i figured it needed to be degaussed, i never got around to it and now the screen has gone completely green on me on every channel. any ideas would be appriciated
  • zsaltyman Apr 04, 2009
    double set of lines about every two inchs all the way down the screen . the lines are on a slight angal aswell there is a greeb tint to the picture
  • 71 Answers
Hi sir you have got a fault in the matrix board it is a kind of three amp. that drives the three colours to the screen so you have the green driver deffect manythings do that maybe a bs dout put transistor or a bad driver ic gain voltage and maybe a dried up capacitor that filters the green input or at last a bad screen green gun these things may be checked only bay qualified person to see the problem please don't forget to rate , remember i am here only to help u thanx
Posted on May 08, 2007
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Fan operates on x3 but no picture
Very likely your bulb. Could also be your ballast.
Jan 08, 2009 | Office Equipment & Supplies
BLACK LINES ACROSS THE SCREEN Panasonic PT-47WX51E
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Trouble with the red cannon
Hello, is the blue blur the only blue on the screen? The reason I ask is because the vertical defection to the blue CRT might be going bad and producing a blue line across the screen. I doubt that it is a convergence problem, but it may also be a magnetism problem and you may need to degauss your set with a degaussing coil (check ebay for specials on this device). I have seen a lot of the projection TVs end up needing to be demagnetized (degaussed). Try degaussing it first and then look at the possibility of a vertical deflection problem and then possibly a convergence issue.
Sep 26, 2007 | Toshiba 50H72 50" Rear Projection...
SLIGHT GREEN TINT TO PICTURE
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Feb 26, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
Oct 14, 2006 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Philips 30PW850H 30" TV Logo
257 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
