Question about Uniden EXA15580 Cordless Telephone
Handset ringer is off, how do I turn it on?
I have read my manual but cannot find the answer. I do not see a Ringer Off button, where is it? I have a Uniden EXA15580
Shove the phone in your booty and it should turn off quick.
Posted on Dec 29, 2008
I have a new uniden cordless D3097 series phone and I can't figure out how to have the handset ringer on and the base ringer off. When I turn off the base, the handset stops ringing
The Silent button on the D3097 is a global Do Not Disturb button. To reduce the ringer volume, press the Volume Down button on each handset when the phone system is in standby (not in use). When you have pressed the Volume Down button to the point where the ringer is muted, you will see an icon of a bell with a line through it.
See pages 6-7 of the manual for the details. The manual is available here: http://www.101phones.com/content/pdf/uniden/D3097.pdf .
I hope this helps.
Sep 18, 2017 | Uniden Lands Phones
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Handset does not ring but the answering machine unit does
Go into menu settings from head set and make sure ringer type is slected for a tone and then check and set volume at desired level
Apr 15, 2013 | Uniden 2.4 GHz Cordless Phone System
How do I reset ringer to "on" if it is set on "off"
Hello
Press "Prog" on the handset.
Press the arrow button beneath the phone's display until you reach "Ringer," then press "Select."
Press the arrow button until you reach "Ringer On," then press "OK." The phone should beep to confirm your selection.
Method Two
Press the down arrow key until you reach "Ringer Vol," then press "Select."
Press the up arrow key until to increase the ringer volume you want then press "Select."
Apr 11, 2011 | Vtech 5.8 Ghz Handset Cordless Phone...
The ringer is turned off. How do I turn the ringer on? also can I buy another owners mannual
To set the ringer volume of the base unit, press FUNCTION/EDIT, scroll to Ringer Setting using the up or down arrow keys of the navigator key(lower right of base unit), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the right arrow key to save the setting.
To set the ringer volume of the handset, press the CONF/FUNCTION button(lower left) on the handset, scroll to Ringer Setting using the up or down arrow keys of the navigator key(center of the handset), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the soft key SAVE to save the setting. (There are three softkeys directly under the LCD screen of the handset whose functionality can change according to what is on screen)
The manual can be downloaded from the link below free of charge.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
Mar 28, 2011 | Panasonic KX-TG2770 Phone System w/...
CAN THIS PHONE RINGER BE CUT OFF
To cutoff ringer volume in Vtech cordless phones,you have to turn off the base ringer.
Handset:
program button->up/down" key to cycle until you see the Ringer selection->up/down" key(s) to cycle until the OFF selection
Base Ringer:
Menu->press menu until you hear "Base Ringer, to change base ringer press change"->PLAY/STOP button to save
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
Uniden 5.8GHz can't turn ringer on
You should be able to go to the handset and do that.  Hit the button above the caller id until you can hear it.
May 14, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I can not find my manuel. How do I turn on the
Adjusting the Ringer Volume
You can choose from four ringer volume settings on the handset (off, low, medium,
and high). With the phone in standby, use the up arrow or the down on the handset to adjust the
ringer volume.
You can find your manual online in PDF format here:
http://www.uniden.com/pdf/TRU9360om.pdf
Apr 20, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Uniden EXA15580 Cordless Telephone Logo
220 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
