Question about Akai Dc7370 Digital Camera
Cannot recognize my camera in the PC
I can't print my photos in my printer because my PC doesn't recognize the device so I can do anything with the photos.
  • 3 Answers
First, check to make sure your usb cord is not damaged and has firm contact in both the usb slot on your PC and the slot on the camera. If everything is OK there try re-installing the software.
Now, if none of this works, that does not necessarily mean the camera is the problem. If you have another PC or can use a family member or friends, then try connecting to a different machine. If the problem is the same then you may need to have the camera checked out (but don't run off just yet, I'm not finished).
The above should tell you if the problem is the camera or the computer. If it is the computer, you should do a thorough cleaning and optimzation of your PC and then check things out. If it is the camera, try transfering your images to the SD Card and use your PC to read the card.
As far as the camera goes, you should still try and make sure all connections are good and firm and your batteries are fresh and strong before spending money on a repair.
Posted on Dec 29, 2008
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
I have a Lexmark printer that is causing me problems. When I switch it on the display stays black or looks like snow and I can't scan anything from the printer. When I try scan from my computer it says...
4. Reboot your pc.
Sep 15, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
It want print anything!
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark C533DN InkJet Printer
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Cnt print laxmark z517 printer
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nHygRf. Select your operating system, download and execute the file.
Aug 14, 2011 | Lexmark Inkjet Z517 Photo Printer
How to set Sony W570 camera so that when the photos are printed, the date of the shot appear on the prints?
Hi Most of digital camera doesn't have imprint function for date. User only can recognize by file date information. If you find it, would you let me know? Thanks and best regard!
May 24, 2011 | Sony Cyber-Shot DSC-W570 Digital Camera
Our printer will not recognize our memory card. We are inserting it in #3 slot. This card was used in a Cannon EOS 60D camera. It will pull up cards from another camera.
Try reading the card with another device such as a computer card reader, also make sure there isn't some sort of lock switch on the card. If the card will not read in another device it is probably faulty and needs to be replaced.
May 11, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Bad USB conection?
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Feb 05, 2008 | Pentax K100D Digital Camera
Bad USB conection?
it's not likely the cable went bad.  Do you have more than one USB port you can try? do you have other USB devices to test the port? did you reboot?
Oct 12, 2007 | Pentax *ist DL Digital Camera
Akai Dc7370 Digital Camera Logo
118 people viewed this question
Top Akai Cameras Experts
Are you an Akai Camera Expert? Answer questions, earn points and help others
