Question about Dell 3200MP Multimedia Projector
Pictue shakes I turn my projector on and everything is fine. Then about 3 to 5min the screen starts shaking then a few mins later it turns off
  • 3 Answers
Your color wheel and sensor assembly has become dusty, remove the bottom screws (except for the foot) and one side screw to release the top cover. Watch the ribbon cable from the top case buttons! Carefully blow out the case with CLEAN compressed air paying special attention to the color wheel. Even if the inside looks clean this is the usual fix. Reassemble.
Posted on Jan 15, 2012
This generally means you need to take it apart carefully and blow it out with a can of air. no vacuum.
Posted on Apr 24, 2008
Sounds like the lamp needs to be replaced. Does the "lamp" light on the top turn solid orange when it turns itself off? That's an indication that the unit has sensed that the lamp is no longer "good".
Posted on Aug 27, 2007
SOURCE:
New holland LX885 WON'T START AFTER I HAD IT RUNNING AFTER SERVICR AND BOOM SHAKES GOING UP. BEFORE SERVICE BOOM WORKED FINE. CHANGED FLUID PER MANUAL
Boom shake is most likely just air in the system. Run it and use the boom till it stops shaking. This happens sometimes after a service on the hydraulics and filter change. As for it not starting after a bit, check that the cold start sensor is working properly. If it will start with a small spurt of ether, then it's not getting the fuel to start up. The cold start system will care for that, and the temperature sensor must work to do so.
Mar 25, 2018 | Cars & Trucks
Car loses power (engine still on) and engine splutters and shakes then turns off when idling
Probably the air flow meter probably dirty can of comprest air take it off spray it
Oct 29, 2017 | 2000 Renault 181
Wont start sometimes
GM cars have bad problem with security system. If you key turn light and will start other time will stick and need shaking to turn over and won't start just replace the key. Security system need some times to refresh the memory.
1.turn key ON for 10min.
2.turn key OFF 10sec.
3.turn ON 10min.
4.turn OFF 10sec.
5.turn ON 10min.
turn OFF ON and start
total of 30 min. to refresh the memory
the next step is more expensive and need some skills.
on top of the ignition switch is a sensor go bad
replace ignition switch with the sensor and do the learning process from step 1 to 5
Apr 15, 2014 | 2004 Pontiac Grand Prix
2003 BMW 325 I won't start. Black smoke from exhaust and stalled
Hi. This is a common fault with m50/52/52tu engines. Engine is flooded because you did not warm it up. Must be out of blue on temp gauge be for you turn off.
Feb 11, 2013 | BMW X3 Series Cars & Trucks
Screen shakes and red lines go through screen?
can you tell me the brand and model number of the set?
Dec 04, 2012 | Televison & Video
We use Power Point with our 4100 dell and many times when a new screen is selected the projected image shakes 2 or 3 times in less than a second. Then is fine untill a new selection is made. Almost looks...
This called syncronisation. try different resolutions on pc/laptop. it looks like projector does not like source's resolution.
Check the cable, and connectios!!!
Mar 07, 2011 | Dell 4100MP Multimedia Projector
Dell 3300mp Projector Loud Noise
Judging by the mains hum noise and now shaking it sounds as if a motorized component has broken.
Humming could have been the initial jam, then shaking the damaged part attempting to rotate.
Maybe check your cooling fan blades?
Dec 02, 2017 | Dell 3300MP Multimedia Projector
Screen flickering and shaking
My suggestion 2 U is that maybe your TV is the 1 acting up. not the PS3
Jun 09, 2008 | Sony Playstation 3 (PS3) Console
Dell 3200MP Multimedia Projector Logo
282 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
