Acer laptop wont turn on has power button light up
Tryed taking out battery and unplugging power held down start button 30 secs then plugged back in no luck wont power on
  • 1 more comment
  • kennyh1960 Dec 31, 2008
    still under warranty so i sending it back
  • o_monn9473 Mar 31, 2009
    acer laptop 5610 will not get any power at all
  • Brain79106 May 11, 2010
    Clarification: Does PC power button go on and then off? That would indicate power supply needs to be replaced. If you can handle a screwdriver and know about your case access this is not too hard to replace. Otherwise go to the shop.
    Problem Solver:
  • 11 Answers
This is a common problem with Acer units, both desktop and laptop. The motherboard fails to read the system BIOS at startup. Removing the battery from a laptop merely removes the power source, but not the stored memory. If you are able to locate the CMOS battery, or the cell battery the size of a US quarter dollar, that is the system battery. Remove that, wipe with a lint free cloth (coffee filter) then replace.
If that effort fails upon replacing the cleaned CMOS battery and laptop eneregy source, then a new coin cell may be the solution.
If a new coin cell fails to resolve the problem, the motherboard itself is the culprit. Time for a new laptop or desktop.
Hope this helps you...
Posted on Dec 29, 2008
  • acer-racer Dec 06, 2010
    I had a similar problem - put the laptop on hibernate, came back to it a few hours later and it wouldn't start up.
    Charged it fully - I press the ON button then the green light goes off. I press the ON button a couple of times in quick succession, and the battery light flashes yellow five times.
    Before, a solution was to remove the battery and replace it a few seconds later. This time though, it didn't work. After much Googling and so progress, I realised that I had not locked the battery in place after putting it back in. It seems an Acer laptop won't switch on if the battery is locked in. I locked it, then it came on without problem.
    The problem happened again once more, then I took the battery out for abotu half an hour, and it worked.
    So, in short, a combination of the following should get an Acer laptop to come back on:
    - Charge battery until battery light goes green
    - Remove the battery for 30-60 minutes
    - Replace and make sure the battery is locked in.
    Lesson learned: Don't use the Windows hibernate function on an Acer laptop!
Stuck on loading services
things to try 1-unplug,remove battery - wait 30 sec,reseat RAM,turn back on.2 unplug remove battery hold down power button 45sec plug in,no battery,turn on.3 use startup repair.4 press Alt + F10 to restore.
Oct 20, 2014 | Acer Aspire AS7741Z5731 Netbook
How do you fixe a computer that do not want to get out of sleeping mode ?
Adjust your power settings to not allow the computer to go to sleep when plugged in.
Jun 04, 2014 | HP Pavilion dv7-1132nr Notebook PC
Hi when i plug in the power cord and press the power button the power light comes on then goes off and the laptop won't start its and acer aspire 4339-2618 what can be done to fix this i try holding down...
Try removing the power cord and the battery, wait 30 seconds and then plug in the power adapter while the battery is not inserted. Then try to turn the machine on.
If this doesn't work, there is something serious wrong with the machine and it will need to be repaired by your local computer shop.
Sep 16, 2013 | Acer Aspire Computers & Internet
Unable start
Unplug the power cord
Take out the battery
Hold Power button for 30 sec
Tap Power button 30 times
Put battery back in
Plug power cord back in
Press power button to turn on.
Sep 13, 2013 | Lenovo ThinkPad Computers & Internet
I have an acer 5210 and it wont start at all
Remove the battery and unplug the power cable. Press and hold the Power button for 30 seconds. Release and press it for another 30 seconds.
Re-install the battery and plug it back in. Do you see the charging light come on? If so, try to turn it on. If the charging light doesn't come on, try plugging it into a different outlet.
The power input is usually the weakest point on a laptop as it is one of the most common repair items. I hope this isn't the case for you as it can also be an expensive repair.
Good Luck,
Apr 03, 2011 | Acer Computers & Internet
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
or this:
1. Remove power supply and battery.
2. Hold power button down for 30 seconds.
4. At this point, the blue light and the charging light should both come on, and the computer should start properly.
And check ur operating system for errors by downloading reginout
Aug 16, 2010 | HP Pavilion dv6000z Notebook
Gateway 450ROG Laptop was downloading a video when the screen slowly went all white. I had to power off. I waited a while reloaded the battery and powered up. I got the windows didn't power down right....
You must go through the safe mode and uninstall your graphics driver and install another one, may be you will find more compatible driver with your graphics card and your windows copy on gateway website.
Jan 31, 2010 | Gateway 450ROG Notebook
Laptop no power, power cord lights up
You should try unplugging the laptop from the power and taking out the battery. Then after about 30 seconds plug the battery back in and attempt to turn the computer back on.
Feb 02, 2009 | Toshiba Satellite M40-S417TD Notebook
Acer Aspire 3500 not turning on
Do you get any thing? Lights, indicators, sounds?
Nov 08, 2007 | Computers & Internet
Computers & Internet Logo
844 people viewed this question
David Payne
David Payne
