Question about Linksys Access Point WAP54GP Wireless-G Access Point with Power Over Ethernet, High-Speed Wireless A... (NTWRLSWA54GP)
Wireless router connection problems
Cannot connect to linksys router directly
Trying to add a new computer to network, setup asks for key.
I dont know what the key is how do i find it
    Sergeant:
  • 366 Answers
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Posted on Dec 29, 2008
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
I have a sony ps3 and i have a linksys router , but my sony ps3 is not picking it up or connecting to it , it keeps asking me about the wpa key and i dont know it, what am i doing wrong ?"
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 04, 2011 | Linksys Wireless-G WRT54G Router
I'm having a problem setting up my linksys wireless router. My computer sees the connection but will not connect to it? I've tried the repair option and tried to add a network with out any luck.
As i remember Linksys goes with Straight Through Ethernet cable. Always, good thing is to connect your computer to Wireless Router using LAN port. Set DHCP (Automatic) connection for your computer. After receiving ip from router you can setup your Wireless Router using GUI, and setup your Wireless Network, SSID/Security. From adapter to adapter there can be some misc problem with WEP/WPA/WPA2 and so on, so it maybe your issue, or OS blocking connection to Wireless Networks without security.
Apr 18, 2010 | Linksys Wireless-G Broadband Router
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
I'm trying to connect to my mobile phone and it's asking for the network key. What's a network key?
First connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router settings.
Go to wi fi or wireless menu then find WEP or WAP security code key it is your password to connect wi fi network.If it is in * or # format then add new code so you can connect it with new code.
then save settings and restart router.
Then add that code key in mobile for connect wi fi .
Let me know if you need more assistance.
Thanks.
Nov 11, 2009 | Linksys WRT160N Wireless Router
I an using a linksys wireless router. When trying
connect t\router to computer with ethernet cable.
Then you can access it's configuration with http://192.168.1.1
or
http://192.168.0.1
Then click on wireless then enable wep security then add new password.Then save settings and restart router.It is new password for connect wi fi.
Let me know if you need further assistance.
Thanks.
Nov 03, 2009 | Gateway Wireless-B Router (wbr-100)
Wireless router hookup...
You need to use a working computer with the router then access the router setup page that way you can get the wireless security key, then follow this step:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
When you're already on the Linksys router setup page, click on Wireless tab and look for a sub tab that says Wireless security and there you can find the security key that you're looking for..
Hope that helps..Don't forget to rate the solution FIXYA thank you...
Oct 04, 2008 | Linksys Wireless-G WRT54G Router
I dont know my passphase
hello!
If you dont remember your passphrase or network key, you need to access the router page to check the router wireless settings. make sure that your computer is directly connected to the router to check your passphrase
Step 1: Access the router’s web-based setup page
Step 2: When the router’s web-based setup page appears, click Wireless
Step 3: Click Wireless Security and take note of the current Security Mode
Step 4: You will see your wireless network key or passphrase on this window
May 19, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys wirless g broadband router
I will need the model number to better assist you.
Jan 03, 2008 | Computers & Internet
Computers & Internet Logo
201 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
