Question about Brother HL 8050N Laser Printer
An e50 error has appeared on the menu of our Brother HL8050N
Could you please tell me what the problem is?
Can i fix it myself.
  • 827 Answers
The Service Error #50 is basically a Fusing Unit problem and you may actually find out that you may have to replace that assembly, to correct that error condition.
E50 means fuser malfunction. Try to print a configuration sheet (press 3 x set). If that doesn't work, you've to change the fuser.
There is probably caked ink and dust on a wire connection that touches the grey roller of the fuser (that has two rollers). It seems this will happen to a lot of the brothers. You just clean the connection. It's simple, but you have to get to it by removing a lot of screws, pieces, and wire jacks.
To summarize:
Remove top cover, and various plastic pieces in the back to get to the fuser. Then take out the fuser and find the 2 black wires that lead to the problem piece that needs to be cleaned.
When you have gotten to the fuser, remove the two wire jack connections. Remove the two screws holding fuser in. One of those screws is big with a spring - don't worry, the spring stays in place. The other screw looks normal, but it is a little longer than the other screws so remember where you lay it. Find the 2 black wires on the fuser leading to the problem piece. Remove the single screw holding it in. Pull it out and clean the wire connections. Now put things back together!
This is really specialist work (the taking apart and putting back together) for a simple cleaning end. Not for the faint-hearted!
It will either be a complete nightmare or a fun project for you..
I would personally take it to a specialist and get an estimate, and measure that against the price of a new printer. But, if you feel brave and have nothing to lose, have a go..
So you know what the problem is, but can you fix it yourself? Well that's down to you, I can't answer that ;)
Chris (ziraffa)
Posted on Dec 29, 2008
My brother dcp 1510 is telling an error massage "replace the toner cartige"i have changed toner ;try to reset but i cant please tell me the exact reset code and procedure .
Hi try this press menu button hit down arrow until u see info on display press OK button hit down arrow until u see reset drum on display press and hold OK button until u see reset on display press start button press-up arrow until u see the value 10 press OK button on display should read accepted press stop until the main menu appear on display.......good luck
Jun 10, 2016 | Brother Office Equipment & Supplies
Why brother laser printer HL-60 show error E50?
Please visit the link below and follow the instructions given for Error E50 to resolve the issue:
http://www.brotherprinterrepairs.co.uk/common-errors/
GuruAid.com
Dec 29, 2014 | Brother Office Equipment & Supplies
How To Repair Error " Print Unable 4F" in Brother MFC-J415W
Sir/Madam
I suggest You Perform Below mention steps To Fix Your brother Printer Issue,
Step1: To clear the message follow the steps listed below:
  1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
    Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
NOTE: The images shown below are from the representative product and may differ from your Brother machine,but their inner structures are same.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover.
3-3.Check the print head's position.
In the example photo the print head is positioned at the left hand side of the platen area.
If the print head is on the left side, go to step 3-4.
If the print head is on the right side, go to step 3-7.
If you can not find the print head, go to step 3-8.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it. 1b555a0b-2eb3-488c-883c-4c7db77f04ff.gif
Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Please contact Brother Customer Service from "Contact Us".
3-7.If the print head is on the right side.
The print head is positioned at the far right hand side, you cannot move it. The machine has a mechanical malfunction and will require repair.
3-8.If you can not find the print head.
Step2: Check if the machine has faxes in its memory
Note
In order to transfer data from your fax machine to another, you must have the station ID programmed in your fax machine.
1.Transfer the Fax Journal Report
Press Menu/Set or Menu on the Control Panel of the machine.
Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If your question was not answered, please check...
How do clear the message Unable to Unable to Chang Brother
Or
If you still need Brother Printer Help Then Follow Us On:
Brother Printer Support
Dec 19, 2012 | Brother Ink for Mfc J415w Printer
Error code 50
Error Code E50. This printer error code flashes when the fuser unit of your Brother multifunction printer gets damaged. When this happens, it is a signal that you must replace your printer's fuser unit
Mar 15, 2011 | Brother Multi-Function Center MFC-240C...
UNIT KEEPS ASKING FOR NEW DRUM EVEN AFTER I INSTALL. ALSO PAPER JAM MESSAGE KEEPS COMING UP
The drum error can be cleared by opening the front door and pressing either the options or menu button. It will ask if it's a new drum and you press 1 for yes. Your paper jam error you will have to look where it's jamming and remove scraps, without seeing it myself I can't tell you what to do to fix it.
Jan 28, 2010 | Brother DCP-8045D All-In-One Laser Printer
My printer Brother HL-6050DN show ERROR E50. How can I fix it?
Oct 21, 2009 | Brother HL 6050 Laser Printer
Bluetooth not working in nokia E50
same problem here. How to i restore my security code?
Jul 01, 2009 | Nokia E50
Turning it on it displays ERROR E50.please help
You have a fuser malfunction, replace the fuser unit.
Mar 06, 2009 | Brother HL 5250DN Laser Printer
Brother MFC-210C All-In-One InkJet Printer ERROR 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart you printer.
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
E50 error
E50 is fuser code, it has blown the heat lamp or thermal fuse. the best solution is to replace the fusing unit. let me know if this helps
Nov 15, 2007 | Brother HL 1850 Laser Printer
Brother HL 8050N Laser Printer Logo
1,789 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
