Question about Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range
Conversion from Natural Gas to LPG
I'm trying to locate either the jets for conversion or a Technical manual for this eurolec 1200DFa dual fuel stove. Also require replacement safety glass for larger oven door
  • Anonymous Mar 23, 2014
    can you convert from natural gas to lpg
    New Friend:
Why can't I get both the upper and lower jets fired up at the same time.
Posted on Jun 14, 2013
    President:
  • 1,462 Answers
Only source will be stoves or their service agents. if uk, stoves is same group as belling and parent company is morphy richards
Posted on Apr 27, 2007
SOURCE:
How to convert LP fireplace to natural gas?
have to get a conversion kit if there is one .
Dec 05, 2015 | Home
Maytag range Natural gas jets to Propane jets
it is a simple replacement but the problem is properly adjusting the air shrouds to get the right air/ gas mixture to burn correctly
lpg jets are available from a gas supply shop and because of the dangerous nature of gas , I would suggest that you have an accredited gas fitter do the conversion
Nov 25, 2015 | Maytag MGR8674AS
Top burners will noty lite
Hello, this is a strange story.
I had this a few times in the opposite and then I found that it was a LPG cooker in stead of a natural gas cooker.
Did you buy this cooker second hand and did not use it before?
When this cooker is normally natural gas, then the nozzles are much larger then when used for LPG, as the pressure of LPG is much higher as for natural gas.
In that case you can change the nozzles for LPG use
Is this a dual fuel cooker with electric oven?
Kind regards, Dik
LPG Jets Cookers Ovens Hobs eBay
Feb 21, 2018 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
Can you convert any natural gas hobs to LPG?
They are convertible. Most come with converting parts attached to the interior of the range.
Feb 21, 2009 | Stoves 1200DFa Dual Fuel (Electric and...
Stoves 1000DF Richmond - LPG Conversion
the back decal will be the original manufacturer and the person doing the conversion would have fitted the LPG decal on the front as a warning to gas fitters carrying ot repairs
The only difference is jet sizes and air shroud positions
I would suggest that you have it inspected by a gas fitter to ensure that the flame is the correct color indicated by the correct jet and shroud position
it should be a royal blue
if a yellow it is wrong jets for the gas
Oct 11, 2017 | Stoves 1000DFDLm Gas Kitchen Range
Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
556 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Carmen Mikulic
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
