Question about Vizio L37 Television
My Vizio 37' flat Screen TV Closed Caption wont turn off
We have turned off everyplace that we know of, but the CC continues to appear on the screen. How do you turn it off?
  • warlock61
    warlock61 May 11, 2010
    do you have cable or satellite?
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
Posted on Jan 10, 2009
  • 5 more comments
  • Lsb3user Apr 05, 2011
    That fixed it. Thank you so much.
  • Bob Hoover Jun 10, 2012
    This worked! There isn't any buttons on our cable box although I pushed "Menu" on the remote and the new menu screen (One we had never seen before) came up. We scrolled to Closed Caption and hit OK. The OK button toggled closed caption on and off. You must hit the power on/off buttom for cable on the remote to get out of the menu. Thank you for saving me a lot of grief!
  • billybooy
    billybooy Sep 01, 2012
    thank you soooooo much!! it worked for me too! was driving me crazy! was looking through the television owner's manual for 2 hours - it wasn't the tv! it was my cable!
  • bfarris538
    bfarris538 Oct 04, 2012
    I just spent over an hour online looking for an answer to this goofy "feature." Your were the ONLY one to correctly address the problem. BIG THANX!
  • Mirm Nov 04, 2012
    We don't have a menu button on our box, but we turned off the box and hit menu button on cable remote. The caption option came up and fixed it for us. Thanks
  • Drunia
    Drunia Nov 27, 2012
    I have no buttons on my cable box, so I just turned it off and pushed the menu button ont eh cable remote and a huge CC menu popped up on the TV screen. and finally got rid of the captions. Thank you so so SO much for the solution. It was driving us crazy. My son fell asleep on top of the remotes and since then, the captions were on and we couldn't get them off for 2 days until I found this answer.
  • Melissa Burns
    Melissa Burns May 07, 2014
    I don't have a menu on our cable box, but I did what Drunia did and it worked. Thanks so much.
My closed caption is on and I can't turn it off. I don'want the writing on the screen
Did you try turning it off with the closed caption button on the remote? Its labelled cc. If you dont have the original Vizio remote you will need to go into menu-settings and find the closed caption and turn it off there
Oct 24, 2011 | Vizio L37 Television
A black rectangle appears in the bottom half of the screen. The rest of the picture is fine, the sound is fine. The box goes away if i press the menu button - but it comes back again. What is wrong?
Do you have a cable/satellite box connected to this tv?
Try this first it sounds like you have the closed caption turned on by accident.
On the remote press the MENU button.
Use the navigation keys to move the selector to CC and press OK.
This should bring up the Closed Caption sub menu.
Ensure that the closed caption is set to OFF
Thanks,
Robert
Feb 26, 2011 | Vizio M220VA 22 in. LCD HDTV
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
Can't turn closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
Apr 04, 2010 | Olevia 237T 37 in. LCD TV
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Removing closed captioning
Worked it out. The Direct TV remote has a yellow button and that did it. I don't know whether I had inadvertently programmed it that way but problem gone.
Thanks.
Jan 18, 2009 | Philips 42PF9631D 42 in. Plasma Television
Can't turn off closed caption & not its not on the TV menu
I went to menu, special features. then select analog CC and selected OFF.
Dec 27, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Closed caption Problem
If the closed caption setting is set to off on the tv then it would definitely be coming out of your cable box. Usually the Cable box will have the setting in the menu's if not i would definily call your cable company and have them switch your settings for you
Oct 17, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Vizio L37 Television Logo
6,545 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
