Question about GE WBVH6240F Front Load Washer
Suds in the floor...
We hooked up a GE front load washer model wbvh6240. It had never been used but it was sitting on the "showroom" floor for awhile and was in storage for about 6 months after we purchased it. Anyways, the problem we are having is that suds keep appearing in the floor behind the washer. Where are they coming from? There's very little water mostly just suds. It usually happens after I've washed 2 -3 loads of clothes in a row. The suds are in the floor behind the washer towards the left side. I have seen a few suds near a hole that has a plastic cap over it on the back of the washer. I don't know what that hole is for and I've only noticed suds there once. Can anyone help me? We just built a new house so this may be a drain issue and not related to the actual washer. I'd hate to have the builder knock a hole in the wall if it is actually the washer : )
  • 640 Answers
Are you using he detergent,,,or low suddsing detergent,,,i believe your putting to much detergent,,and not the right detergent,,,to test run a load with no soap,,and see if you get water on the floor..onthejob
Posted on Jan 28, 2009
Testing the control panel for damage on a front load washer
How to Diagnose Washing Machine Control and Program ...
? 9:08
https://www.youtube.com/watch?v=QYPqpjLV7s4
Nov 11, 2013 - Uploaded by eSpares
I have a bosch front loading washer that's doesn't have code board. .... there's a clicking behind the front ...
[PDF]GE Front Load Washer - Atech Appliance Repair Service ...
www.atechappliancetechnician.com/GE_Washer_FL_WBVH6240__WC...
Louisville, Kentucky 40225. 31-9135. GE Front Load. Washer. WBVH6240. WCVH6260 ... damage. The man u fac tur er or seller cannot be responsible for the ..... Service Test Mode . .... accessible on the control panel's 7-segment display.
Jan 05, 2016 | Washing Machines
WBVH6240FWW GE FRONT LOAD control counts dow to 9 mins then jumps back to 11 mins in rinse and drain. I replaced the control. What else could cause this problem
Too much soap generally causes it to change time. Soap causes motor overload. The control detect over amping and declares a suds error. All machines have this built in though many do not display the error. Items between baskets can also trigger this.
WBVH6240 service manual
Apr 04, 2011 | GE WBVH6240F Front Load Washer
My question is; the washer,model,wbvh6240 has any filter
No , all new front loads have a self cleaning filter. Therefore nothing needs to be emptied or clean. The little trap door in front of the washer is to drain it in case of a power failure when the washer is full of water. .
Mar 15, 2011 | GE WBVH6240F Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
WBVH6240 Spin problem. Excessive vibration during spin. Loud noise when reaching top spin speed.
There are little items called "dogs" that keep the drum in balance. You can view a diagram of the machine and parts at partselect . com.
Bad bearings could also due this, but you would see oil/grease on the floor and chunks of the couple laying around. The dogs stay in place but will wear out.
Jun 22, 2010 | GE WSXH208A Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
GE front loading washer WBVH6240 leaks during fill cycle..solutions??
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Washing Machines
Replace rubber gasket
Replace the machine with a top loader and you'll never have a leaking gasket again! Worked at National Linen for a while and the floors had drains in them and were always wet! Needless to say the pros have the same problem you do! ;)
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Washer
I have notice this problem with a lot of front loaders. I would check the manufacture warranty to see with is covered and if you bought an extended warranty, use it, keep your receipts for your previous purchases.
Dec 11, 2017 | GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer Logo
90 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
