I've charged the battery, checked all the connections that I can find. Ignition switch on, run switch on, still no start.
SOURCE: WHERE ARE THE FUSES ON
under the panel in front of the left saddel bag as you stand behind the bike also starter releay is on the other side
SOURCE: I have a 2007 Electra glide Ultra Classic. The cruise will not e
You may need a new ECM module .
SOURCE: my harley davidson electra glide ultra classic
Check to make sure "RUN" switch is on.
It is also possible the "START" button is bad.
SOURCE: no start 09 Ultra Classic Electra Glide
Sounds like your charging system is not charging the battery.
Put a volt meter on the battery, run the engine up to maybe 2,000 RPM. The voltage must be at least 13.8V, but not more than 14.5.
If that is all OK, your battery is worn out, and is not holding sufficient reserve. It would need to be replaced.
Testimonial: "waiting on dealer to get back to me...voltage meter on bike reading between 14-16"
