Question about Intel Desktop Board D845GERG2 Motherboard
Problem booting "cdboot memory overflow error"
I cannot boot my machine(Dell Inspiron 1501). Tried booting from original DVD and getting this error.
cdboot: memory overflow error
Any help?
  • toots_iz_me May 11, 2010
    think you need a new hard drive...or graphics card..maybe
    Genius:
  • 1,066 Answers
Your ram or memory controller may be bad, try taking out one of the ram chips or swapping them with each other. try running memtest86 (you can google and download it) to check for memory errors.
Posted on Dec 29, 2008
Dell Inspiron will not boot up or let me reinstall discs
If you want to use discs to reinstall make sure you change boot order in the bios settings. You want it to boot from dvd drive first.
Dec 14, 2013 | Dell Inspiron 1501 Notebook
My dell leptop refus starting i got message : Primary hard disk drive not found , CDBOOT ; Memory overflow error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude C800 Notebook
My dell inspiron 1501 has a error 0xc0000011 windows failed to load because the system registry file is missing or corrupt also would not load any cd
Go into your bios and make sure that your cd drive is the FIRST BOOT device. Then load the dvd and run a startup repair.
Mar 20, 2011 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 wont trun on
There are a couple of things you should try:
Try booting with the battery out, check the power supply does it have a solid green led?
Remove both memory chips and try booting with just a single chip.
Any noises, led blinking, etc?
The more info you give me the quicker I can help.
May 25, 2010 | Dell Inspiron 1501 Notebook
Is there a way to update the BIOS if you cant get the computer to boot
It depends -- does your computer have the capability to boot from a USB memory-stick? from a CD/DVD disk?
However, if it does not boot, you should FIRST trouble-shoot that problem, rather than trying to "flash" the BIOS as an attempted solution.
Dec 01, 2009 | Dell Inspiron 1501 Notebook
Inspiron 1501 wasnt booting so reseated memory ram one at a time. it will boot with 1 memory ram but not 2. any suggestion
check both memory slots with the same stick of ram. Possibillity :bad slot or bad ram stick.
Oct 31, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1526 laptop won't boot up
The 2000-0147 error is normal as you had no disk in the optical drive to be read during the test. Boot to the Vista DVD and select the repair my computer option (you may have to run the repair process several times depending on the issues with the drive) See if that helps. If no go, then a reinstall of Vista is likely
Oct 03, 2009 | Dell Inspiron 1501 Notebook
No power on my laptop inspiron 1501
you have just tired everything. i think your mainboard is broken down. you need to take it to the service.
May 27, 2009 | Dell Inspiron 1501 Notebook
I got a system form my school with no HDD. I got a standard IDE interface seagate baracuda 7200 rpm 160 GB HDD. I tried booting the system with a boot CD. But the error it is showing is CDBOOT: Memory...
If you have both a CD drive & a DVD drive, make sure you are using the 1st physical device (according to physical hookup).
Or if you do have both, then try booting with CD in other drive
Dec 27, 2008 | Computers & Internet
Screen blank no starting
Make sure it is the same speed,etc as the original::
NOTE: To get maximum performance/dual-channel memory bandwidth capability, both memory module connectors must contain memory modules and the modules must be of the same size and configuration.
note.gif NOTE: If a memory module is not installed properly, the computer does not boot.
Jan 17, 2008 | Dell InspironTM 1501 Notebook
Intel Desktop Board D845GERG2 Motherboard Logo
1,038 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
