Question about HP Office Equipment & Supplies
Wirless Printer won"t network with the router
Wireless printer will not connect to router so i can add 3 computers for use of the printer I have a photosmart C8100 all in one printer..
    President:
  • 948 Answers
Check your wireless security settings and make sure the mac address of your printer is allowed to connect to the router. In addition, I would set my printer to only allow incoming connections from the router or you will have people driving by, printing ads that you probably will not like.
Posted on Dec 29, 2008
How do I add printer to Netgear router N600? Printer won't connect to network?
download driver and software from the following link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategor%E2%80%8By?cc=us&lc=en&dlc=en&product=3940574
In order to achieve wireless capabilities you need to temporarily connect a USB cord into the computer and printer to find your wireless network through the HP software. If you have a Windows computer and the Solution Center is already installed on your computer, then follow these steps:
1. Go into Devices and printer
2. Right click on the printer, select remove device
3. Click on your Start Menu, then All Programs
4. Click on the HP folder
5. Click on your printer, then printer set up and software
6. Click on add a new printer, click on wireless (This is where you can temporarily connect your USB cord)
Dec 23, 2013 | NetGear DG834G Router
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
How to hook up a wireless printer to a computer
Does the printer also have some "wired" interface (parallel-port, or USB-port)?
If not, then you need to purchase a router with wireless capability:
1. Connect cable-modem (or DSL-modem) to the 'WAN' (or 'IInternet') port on the router.
2. Connect one of the 'LAN' ports on the router to the network-port on your computer.
3. Configure the wireless-adapter inside the router:
* set an SSID -- the "name" of your wireless network
* encryption-level -- use 'WPA' or 'WPA2'
* a password for your network
4. Configure the wireless printer to connect to that SSID, using the password
5. On the computer, click "Add Networked Printer"
6. Print a "test" page: computer -> wired -> router -> wireless -> printer
Mar 18, 2011 | Canon Office Equipment & Supplies
How can I connect my printer to my wireless network
If you have a wireless-enabled printer, you can use the printer's configuration to connect it to the router. If you have a wired connection printer (ethernet port) connect it to one of the ports on the back of the router with an Ethernet cable and the printer should sort itself out. If your printer is not network-enabled, you will need to connect it directly to a network-connected computer, then use Windows' sharing settings to share the printer to the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
How do i set up my hp 1012 printer to print wirelessly?
1.Position the printer near your wireless network's router. Plug an Ethernet cable into the Ethernet port on the back end of the printer. Run the other end to any of the numbered ports on the back side of the router. Press the "Print Report Page" button on the printer.
2.Navigate to the setup page listed on the report page and click the tab labeled "Networking."
3.Scroll to the "Connections" heading and click "Wireless." Navigate to the tab labeled "Wireless Setup." Click the "Start Wizard" button.
4. Follow the prompts to connect the HP 1012 to your wireless network. Click "Finish" and close the browser.
5.Open the "Start" menu and navigate to "Network." Choose the "Add a Printer" option. Click "Add a network printer."
6. Click "HP Laserjet 1012" and choose "Next" and "Finish" to access the printer through your computer's wireless connection. Repeat the process of adding the printer on any other computers on the wireless network.
Please follow these steps and let me know if it works or not
Nov 01, 2010 | HP LaserJet 1012 Printer
How do I set it up for wireless
Install a printer on a home network The most common way to install a printer on a home network is to install it as a stand-alone device on the network, and then add a connection to the printer on each computer that is on the network.
If you're not sure what type of network printer to install, decide if you want to:
  • Use a wireless printer. These printers use a built-in wireless card and plug into a power source, not your network or computer. After you turn on the printer, you need to refer to the information that came with the printer to set up a wireless connection to each computer on a home network. Security options for wireless printing are determined by each printer manufacturer.
  • Connect a printer directly to the network. To do this, you need to plug in the printer to your network hub or router. How to install these printers depends on whether the printer and your network device use an Ethernet, universal serial bus (USB), or another type of connection. You also need to refer to any installation information or tools provided by the printer manufacturer.
  • Connect more than one printer directly to the network. To do this, your hub or router must be able to support more than one printer connection.
Hide all expcol_imgs.png To install a network printer
  • To find out how to install a network printer, check the information that came with the printer.
expcol_imgs.png To connect to a network printer After you have installed a network printer, you need to add a connection to the printer for each computer on the network.
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. On the toolbar, click Add a printer.
  3. In the Add Printer Wizard, select Add a network, wireless or Bluetooth printer, and then follow the steps in the wizard.
Feb 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Trying to connect printer to computer wireless
  1. Step 1 Check if your printer is network ready. Many newer models are designed to work on networks. Examine the documentation to see if your printer supports Wi-Fi (802.11x) or Bluetooth.
  2. Step 2 Add network support to your printer. If your printer is not already wireless you can connect it to a wireless routermag-glass_10x10.gif using the RJ-45 Jack (it resembles a large telephone jack). You can also buy an expansion card that will add a jack or buy an external print server that will connect to the USB or parallel port.
  3. Step 3 Connect your printer to the network. If your printer is not wired, you’ll have to connect it directly to your wireless router. Connect a networking cable from the RJ-45 Jack on the printer (or adapter) to the router. Plug it into any jack except the UPLINK. The printer should automatically connect to the network when turned on.
  4. Step 4 Install printer drivers on all computers. Using the disc that came with the printer or drivers downloaded from the manufacturer, install the printer’s drivers onto each computer on the network.
  5. Step 5 Print. You should be able to access the printer just like any other wireless device. Select the printer from the Print menu when you print.
  6. Share Your Printer in Windows
  7. Step 1 Install the printer. Set up the printer as normal on a machine that is already connected to the wireless network. Connect all necessary cables and install all necessary drivers.
  8. Step 2 Open the printers and faxes folder. Click "Start," then "Control Panel," then "Printers and Other Hardware" and then "Printers and Faxes."
  9. Step 3 Share your printer. Find the icon for the printer you just installed. Click the icon once and then select SHARE THIS PRINTER in the tasks pane on the left. Now, right click the icon, select properties and go to the SHARING tab. Click "Share Name," and then click "Okay."
  10. Step 4 Connect to the printer. On the other computers within the network, open the control panel and click "Printers and Other Hardware." Select "Add a Printer."
  11. Step 5 Select "Printer Connection." When prompted, select this option instead of the local printer. Find and select the printer you just installed and select it.
  12. Step 6 Print as normal. Next time you print a page, send it to your networked printer.
Hope this Help.
Cheers!!!!
Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
Printing to a network via wireless router
Usually wireless routers prohibit master browser (network neighborhood) communications from traversing between the wireless and wired computers. You can usually overcome this by setting a static ip address for the computers with the printers so that they are not a moving target (addresses are always changing with DHCP). Then you can use UNC paths to get from wireless computer to your target on internal network. For example, to connect to printer (with shared name BrotherH) on a wired computer with static ip address of 192.168.0.19, on wireless computer create a network printer and manually enter the address \\192.168.0.19\BrotherH , now the wireless computer should be able to traverse and connect to the wired printer.
Your wireless router should have a pool of static ip addresses available, say 192.168.1.1-49, you can specify this to your liking, and then you can also have a block of handed out DHCP numbers, say 192.168.50-60 or whatever.
Jan 26, 2009 | Linksys Wireless-G WRT54G Router
240 people viewed this question
Ben Johnson
