Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Convergence no adjustment
On this mitsubishi 40" vs-430ca projection tv I have changed the convergence chips and had no change there is no convergence adjustment function happening with the alignment buttons .trying to set the convergence has no effect. there is still a picture and sound but the picture has the top /bottom coloured bows I have not changed any resistors in the convergence circuit because I have no clue which resistors go bad . On my 60" zenith I fixed it with an r 3243 resistor on the smps module . could a person in the know about which resistors (and their values) go south in a mitsubishi set please let me know the rundown list and the approx placement in the set.
  • rick werbeski Apr 27, 2007
    I could not figure out how to put my set model and name under it's own name and ended up listing it under this 52525 projection problem listing I would fix this foulup but I do not know how..
  • gpacanada Dec 31, 2008
    i have same problem with mitsubishi VS-430ca model
    Is there a factory reset on the TV?
    My dad has had this unit since 1988 and i would like to have it running and keep it if the costs permit.
    Any solutions would be greatly appriciated.
    thanks
    AA
    President:
  • 3,130 Answers
There are black in color circuit protectors in the set that have blown because of the bad convergence IC's. You will need to measure the voltages on the ICs and make sure you have the correct plus and minus voltages. There should be about + and - 24 volts on each IC. I'm afraid the only way you will know what voltage are what and where they should be would be to get a service manual. i am sorry i do not have this model to share with you. Good Luck.
Posted on Apr 27, 2007
I have a 12 yr old Mitsubishi projection tv model vs 60607 with a red/blue convergence problem. Can it be fixed?
It should be fixable----this model uses two of the STK-392-110 chips for convergence.
If it adjusts but will not remember the adjustments either a bad solder connection on one of the chips or a problem with the DCM---digital convergence module which stores adjustments.
Adjustments in customer menu may not be being stored--
Jun 10, 2012 | Televison & Video
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
I have a Mitsubishi Rear Projection tv (vs-50705). The picture shows a concave image on the top and bottom of screen and the edges go off the screen. I have red blue and green ghost images on the screen...
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Jun 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi Rear Projection makes funny shapes on Green and Blue
Your Green and Blue horizontal video amplifiers have collapsed: try using a freon cold spray on these chips as this occurs when the heatsink grease dries up on the HVA chips and, causes an overheat condition; if you have an oscilloscope monitor the vert drive as well.
May 20, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Turned TV on and screen has a concave look to it.
change the convergence chips or lack of voltage in the chips get advice from tech never your home
May 04, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
