Question about Dryers
Dryer makes lound sound when trying to start and will not start.
Basically, the dryer will not work. It makes a loud buzzing noise when I push the button and will not start? When it did run it did give off a smell of somthing buning?
  • 115 Answers
You have a bad motor
Posted on Dec 29, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' ...
? 4:32
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer Making Lound Wobbling Noise
I'll bet the drum is cracked.
Jan 11, 2009 | Dryers
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
175 people viewed this question
Top Dryers Experts
