Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice smells. The water and ice from the indoor icemaker has a smell.
    President:
  • 3,113 Answers
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
Posted on Apr 30, 2010
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Why does the ice from ice maker have an awful smell and taste? Is there a filter that needs to be replaced?
i found that the previous homowners hooked the icemaker to soft water instead of hard water. Once I changed it to hard water, both ice cubes and water tasted fine.
Jul 09, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Water would not stop running into icemaker, now
The water inlet valve(where the water supply connects to the back) may have been staying open and now has burned so it don't work at all. . You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Mar 25, 2010 | Refrigerators
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
There is a burnt smell emanating from my freezer. The ice maker isn't making more ice. My freezer had been left ajar and there was freezer burn on several items. We shut the freezer and after two days I...
Pour about 1/2 cup of water into icemaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the icemaker . Also make sure the refrig coils are clean and free of dust , lint , pet hair , etc....
Aug 18, 2009 | Frigidaire FSC23R5D Side by Side...
Smell in kitchen water
Is your supply line plastic or copper? If its plastic then that can absorb a smell. There is nothing in the icemaker that would make it smell. You may need to replace the supply line and the inlet line that feeds the icemaker. Is there a smell in the kitchen faucett?
Aug 12, 2009 | U-Line BI-95
Ice maker ice smells
Dump out the ice, let the icemaker refill the ice container, dump all that out as well and then it should be cleaned of whatever was in the line..
You may want to roll the fridge out and visually check the supply lines on the back of the fridge for contamination as well.
Jul 02, 2009 | Freezers
Not making ice, indoor water spout working
Check the temperature in the freezer. The temperature must be below 0 degrees for most icemakers to perform properly.
Jun 14, 2009 | Refrigerators
Odor
Replace your water filter and totally clean your icemaker. Check the drip pan under the unit if you can smell it through the whole house. You have more than an icemaker issue.
Apr 12, 2009 | KitchenAid KSRG25FKSS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
