Question about Monster Cable (109611)
I am about to replace the 2WIRE router. Why? Wireless is not wokring properly. My new macbook does not connect to it that good. It drops out. I experience this problem most of the time. Is it possible that other routers will work? I got this plastic internal antenna thing for $19.99 cheap eh?  I am soon going out to buy a Belkin router probably N or mimo. I noticed it is the router because my friend's Powerbook G4 as the same problem too. (The 2WIRE probably hates macs)  It has been a YEAR already and 6 months with the thing. Even sometimes it happens to PCs (I have a 2 Toshibas)    I hope this is enough information for all of you reading this. Please reply if buying a new router helps. Thanks. JC
    Scholar:
  • 46 Answers
The new router should help because of the extended range that they have. You may also have an issue with your computers wireless device. I wiould recomend seeing if you can connect to someone elses wireless device before making the purchase of a new router. Some computers have a weak wireless adapter built in.
Posted on Dec 29, 2008
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
I have a wireless connection problem between my macbook and my 2wire modem. It keeps dropping the connection.
If you can check the 2wire website for your router model and see of there is a firmware update. Also if you are using a wpa or wpa2 security try lowering it down to wep. Wep is less secure but it also provides more compatibility with many devices.
Here is a link to the support page for there routers:
http://support.2wire.com/index.php?page=download&cat=1
Mar 06, 2011 | Computers & Internet
Having problems with 2wire router that keeps dropping the internet. All light are on except ethernet, does this mean the router is no good. Recently replaced the power cord which helped for awhile.
how do you connect to your router? If there's no ethernet cable plug in on the router, the Ethernet light on your router is suppose to be off. Also try to move your router 2-3 ft. away from any electrical devices like wireless phone, printer etc. because of electromagnetic interference. It may help your wireless connection to be stable and faster.
Jan 09, 2011 | 2wire (2701HG-B) Wireless Router
Can I use old 2wire router to connect PC to new wireless router?
Hi, You can not use a router to connect a computer to another wireless router. You need to purchase a wireless adapter if you want to connect a computer wirelessly to the network. There seems no other way of doing this.
Let me know if you need any further help regarding this.
Regards
Anand
Aug 03, 2009 | Computers & Internet
Where do I locate wireless router settings SSID?I am trying to set up a wireless HP Photosmart C6380 All-In-One to connect to my new Macbook?
Go to your Router's "System Summary" and go to Home Network tab. Then click wireless settings. SSID = Network Name.
Jun 16, 2009 | 2wire 2700HG-B Router (2700HGB)
2Wire 1800HG keeps losing connection
However as you said Desktop works fine and this seems to be issue with Wireless Netwrok card of your Laptop try to upgrade drivers of the Wireless netword card opf your laptop and this may possibly resolve the problem..
Apr 08, 2009 | 2wire 1800HG Router (RG1800HG00)
Getting ready to replace my 2WIRE router
The solution may be as simple as placement of the router/antenna, or it may be a configuration mismatch between the MacBook and the router. 2Wire is a fairly common router used by some ISPs, the router might be configured to use IPv4 and the Mac might be configured to use IPv6 (different address schema), or the channeling might be set different (encryption setting mismatch). Since the problem seems to occur mostly with the newer computers, I would lean more toward a configuration problem, but recommend checking the antenna first (this would automatically transfer to a new router), then check the settings. Depending on the environment of the router, the time may have come to get a new one (I have seen some last many years and some last only months).
Check that the following are set the same on the router and the Mac's:
  • IP Addressing schema
  • Encryption settings
  • Channel and frequency settings
If you are going to relace your hardware, I recommend a router with MIMO technology using the 802.11g standard. As far as the 802.11n standard, keep in mind that it has not been approved and published in its final form yet, this could mean that any technology using this "pre-standard" may become obsolete and unusable overnight.
Dec 29, 2008 | Monster Cable (109611)
Getting ready to replace 2WIRE router
MAKE SURE THAT THE ROUTER IS NOT INSTALLED ON A CARPETED FLOOR: EVEN THOUGH YOU CHANGE ROUTER AND IT IS STILL WITHIN AN AREA THAT IT may encounter interference FOR THE WIRELESS SIGNALS
ANY ROUTER WOULD DO.
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
Monster Cable (109611) Logo
71 people viewed this question
Top Monster Cable Computers & Internet Experts
David Payne
David Payne
Are you a Monster Cable Computer and Internet Expert? Answer questions, earn points and help others
