Question about InFocus In2102 Projector
Infocus projector, words projects backwards - InFocus In2102 Projector
  • 82 Answers
Change the orientation from rear to front in the menu
Posted on Jul 26, 2009
  • sridhar C Jun 21, 2014
    change the settings from rear projection mode to front projection
    Scholar:
  • 141 Answers
In the image settings, probably set for rear projection. Need to switch back to Front Projection.
Posted on Aug 06, 2009
  • 2,237 Answers
It's set on 'rear projection'. go into menu and change image to 'front'. or select 'factory reset'.
Posted on May 28, 2009
  • 528 Answers
Goto menu and change the 'Projection Mode'.
Posted on Jul 30, 2009
  • 36 Answers
Your screen is set for rear projection, go to menu, display and switch to front view.
Posted on Jul 10, 2009
Words are showing backwards
Your projector has been set up for rear projection - you need to change it to front projection. Access the setup menu, then use the option to flip the image horizontally. Viewing the image in a mirror may make it easier for you while navigating through the menu options
Mar 27, 2014 | InFocus Office Equipment & Supplies
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
Mar 27, 2014 | NEC VT465 Multimedia Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Projector projecting backwards or like a mirror image
    you have it in rear projection mode. Do the following go into settings>system menu and turn off rear in settings>system menu.
    Jun 07, 2010 | InFocus LP640 Multimedia Projector
    I have a sony projector ceiling mounted, the image is projected
    go into the menu and the image settings. there is a selection for front, rear, ceiling front, and ceiling rear. it might be sent to ceiling rear, so change it to ceiling front.
    Dec 15, 2009 | InFocus In2102 Projector
    When i turn on the projector it turns off and displays the wrench symbol on the infocus project. need help
    there is an issue with either the colorwheel or the power supply. send it in th an infocus service center. try av solutions in ny. they're pretty good.
    Nov 04, 2009 | InFocus In2102 Projector
    Doest function.no image projection,fun does not function
    fuse on ac filter board. if that's ok, there is a power supply issue.
    May 31, 2009 | InFocus PROJECTOR LAMP, Projector Lamp FOR...
    Slanted Border- Projector image is not square
    Is the image slanted on the bottom as well?
    Make sure the projector's throw is pointed directly at the target ie. screen or wall etc. there's not much else it could be.
    Jan 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Problem with projection Infocus 5700
    the light tunnel has collapsed and part of it is blocking the image. find an infocus service center to have them fix it because they don't sell the part.
    Oct 27, 2007 | InFocus ScreenPlay 5700 Multimedia...
    InFocus In2102 Projector Logo
    1,364 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
