Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Screen and volume problem
I have been having a problem with my Sony Wega recently. The volume freezes at a certain level and although the indicator moves the volume remains constant. The only way to fix is to turn the tv off and back on. Now when I turn it off and then back on I get a single horizontal blue line through the middle of the screen and no sound. Will do that several times before I can actually get the picture and sounds back. Any ideas?
    Sergeant:
    Champion:
  • 326 Answers
Hello, the problem regarding horizontal blue line can be around vertical output stage with IC(LA78045). Please check for cold soldering, resolder the suspected solderings. Best regards.
Posted on Apr 27, 2007
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Sony LCD has recently started to have a buzzing/humming noise from speakers. When volume set to zero no noise. When set to volume 1 I can hear it. With increase in volume it is gradually becomes less...
I would like to post a Sony statement here, hopefully you can reply with a good word.
Examples of Software Correctable Symptoms
Always check the Sony Technical Support site for any known and listed issues that are software related. Most symptoms that are correctable by software updates involve communications issues with other devices or minor glitches in the operation of a specific function. Below is a list of some of the symptoms that may be corrected with a software update:
• Fluctuations in picture brightness
• Intermittent picture freezing or noise
• Problems with certain inputs (especially HDMI)
• Intermittent or distorted audio
• Erratic remote control operation
• Unit turns on and off by itself
• Loss of color
• Internet connectivity
• Certain features not working correctly
Jun 10, 2010 | Sony Televison & Video
My volume on my sony tv wont go past 12 it will higher and lower but the maximum it will higher to is 12 have i maybe put a volume lock on it??
The only way the volume could be limited is if you were in the hidden tech menu----many of these sets have a setting there for initial volume level and maximum volume level.
Were you in the TECH menu for some reason?
I can tell you how to get in but you have to be very careful if you make any ADJUSTMENTS there--over 200 things can be adjusted there.
Let me know if I can help.
SD TECH
Feb 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
On my Sony Surround Sound tuner, if I raise the volume up to a certain level (not that loud), I get a flashing sign ''protect'' and the sound to the speakers are cut.
Sony has protection in these receivers for two main reasons.
1 - Checking for DC voltages on the outputs to speakers. Not your particular problem.
2 - Excessive current being drawn from receiver on one or more of the speakers.
Number 2 should be your starting point in finding a solution. Put the volume level on Medium - 35 to 40 on the front panel. Now listen to all you speakers in turn. Any scratching noise will indicate a defective speaker. Remove this speaker from the receiver output and check again if the set goes into protection on high volume.
If you could not find any strange noises on the speakers, remove them one by one and test the set on high volume.
Never - attempt to disengage the protection on this amplifier. The only times we have found the amplifier to be defective with this protection error, it has done so no matter the volume level. Therefore I believe your problem to be a speaker or speakers.
Sep 13, 2009 | Sony Audio Players & Recorders
Sony Wega 32in with a volume problem
use it with energy of any shockwave
Jul 11, 2009 | Sony Televison & Video
3 year old VEGA TV: LED indicator 9 times blinking
Use remote control:
display, 5, volume +, power
I can turn on my TV, though with the fault codes on-screen. Holp it helps.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega sound
Sony have alot of audio issues i would suspect audio ic board it is not a hard repair but these sonys are hard to take apart.
I have a tv shop and we do a lot of these estimate would be aroud 200.00 they are very heavy so you would not want to bring it in. Im not sure of road call fees we charge 45.00
thanks DOCTOR VIDEO
Apr 13, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
